Removing Trim From Recessed Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 02-08-2009, 03:17 PM   #1
Removing trim from recessed lighting
It might sounds like a stupid question for most of you, but I cannot figure out how to remove the trim from my recessed lights. On the trim, I can read that they are from "Capri Lighting" but I cannot find anything from their web site.
Anyone has experience with them?
dadaR6 is offline   Reply With Quote
Old 02-08-2009, 03:29 PM   #2
Rewards Points: 6,652
If they are "Snap Rings", you just have to pull the rings off.
Old 02-08-2009, 03:47 PM   #3
A) Pull down
B) Pull down evenly with a twisting motion.
Sometimes there are springs or spring clips. Other times there is a twist lock kind of setup.
220/221 is offline   Reply With Quote
Old 02-09-2009, 01:52 PM   #4
Humm, I tried to pull them pretty hard already, but nothing is coming off When I pull, I feel the light socket is also coming down with the trim!
I will try to take some pictures and post them up.
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 09:47 PM
Recessed lighting in billiard room? kcrossley2 Electrical 11 01-11-2009 08:00 AM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 10:21 PM
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 01:35 PM
recessed lighting in basement DIY4EVER Electrical 6 06-29-2007 02:52 PM
