Old 08-09-2011, 09:53 PM   #1
Removing rust on terminals
What is a good way to remove rust (severe brown corrosion, not the lighter green stuff) from typical device teriminal (capacitors, relays, contactors). As for the female terminals on the ends of wires, I replace them, but I want to continue using the devices.
I don't want something to preserve terminals and prevent rust, but to get rid of it.
Klawman is offline   Reply With Quote
Old 08-09-2011, 10:45 PM   #2
I=E/R
a7ecorsair's Avatar
Most of the devices you list don't have terminals made of ferrous metals that rust. You can get small brass brushes at most hardware stores that will work for this. Radio Shack used to carry contact cleaner. Spray and brush.
a7ecorsair is offline   Reply With Quote
removing rust from a vintage painted cast iron doorstop Margo Painting 6 03-08-2011 04:22 PM
Removing heavy rust papageek General Discussion 8 11-03-2010 03:13 PM
Seeking advice on severe rust buildup issue. YerDugliness Plumbing 2 05-07-2010 07:02 AM
Removing rust from tools Colby Building & Construction 12 11-16-2009 09:22 PM
bathroom sink rust removal? bofusmosby Plumbing 4 11-12-2008 07:28 PM
