Removing Outdoor Electrical Service - Electrical - DIY Chatroom Home Improvement Forum
Old 08-13-2007, 07:53 PM   #1
I would like to eliminate an outdoor receptacle which is mounted on a pole near a pond in our backyard. I would like to keep the service there in case it is needed in the future. What is the best way to terminate the wires?
scchang is offline   Reply With Quote
Old 08-13-2007, 09:52 PM   #2
Eibwen
Do you know where the line for that recep comes into the house?
If so, you should be able to just cap it with wire niuts and leave the wire in place for the run in case you want to use it again later.
Sammy is offline   Reply With Quote
Old 08-13-2007, 10:07 PM   #3
Thanks. I don't know where it comes in. What would you suggest?
Old 08-14-2007, 04:22 PM   #4
i don't think that is a good idea...it will work, but it is still a loaded gun.
you need to locate the source, and terminate it at the source.....there are a million possibilities.probably the most direct route from an inside outlet feeds this...call an experienced electrician for this one, if you can't locate..
Tony Cunningham is offline   Reply With Quote
Old 08-14-2007, 05:49 PM   #5
Agent 000
SecretSquirrel's Avatar
Just plug a drop light into the receptacle and start flipping breakers until you find the one that turns it off. It may be sourced from the panel, then again it may be daisychained from another receptacle. In either case you have some path to trace it. As Tony mentioned it is not safe to leave an unconnected live wire in place.
SecretSquirrel is offline   Reply With Quote
Old 08-15-2007, 12:24 PM   #6
Rewards Points: 1,910
If you are leaving it there how about just putting a locking cover on and leaving it as is.
200 Amp service really needed for a 830 sq ft house? overkill? alexz Electrical 7 11-16-2009 06:54 PM
200 amp panel with a 100 amp service? alexz Electrical 10 07-29-2007 11:00 PM
upgrading service cable Clutchcargo Electrical 1 06-22-2007 11:04 AM
Service upgrade rondo Electrical 1 05-21-2007 07:19 PM
Suspected open/loose service neutral mrtomwj Electrical 5 09-28-2006 09:46 AM
