Removing One Of Two Fans On One Switch... - Electrical - DIY Chatroom Home Improvement Forum
Old 02-07-2013, 01:21 PM   #1
Removing one of two fans on one switch...
Hey guys,
So I am needing to remove one fan completely and patch the hole. There are two fans in the living area on one switch. If I just disconnect and pull the fan, and patch the hole, is this against code? Will it prevent the other fan from working correctly? How would I go about finding out what I need to know if there are various ways it could have been wired...? Any help would be awesome. Thanks!
-Huggins90
Huggins90 is offline   Reply With Quote
Old 02-07-2013, 01:43 PM   #2
Licensed electrician
Rewards Points: 1,234
Before you can abandon the cables you will need to make sure they are dead and removed from the boxes. You will also need to check that the fan you want to remove does not feed the other fan. If it does you will need to leave the box and install a blank cover. You will not be able to bury that box.
Old 02-07-2013, 02:50 PM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Huggins90 View Post
So I am (wanting) to remove one fan completely and (think I need to) patch the hole.
Disconnect and remove the fan.
Safe the wire. (wirenuts in the box .
Install a blank cover.
Old 02-07-2013, 03:49 PM   #4
Ha thanks for the edit tarheeltwerp...er uh...terp. So if the fan feeds the other fan, and I safe the wires and install the blank cover, the cover would still be visible? It mounts externally? Could I pull the box, then connect the wires back together in the attic in a junction box?
Old 02-07-2013, 04:24 PM   #5
MarginallyQualified
...the cover would still be visible? It mounts externally?
You can do almost anything you like...
I suggest using the $5 and 30 seconds til done approach.
Old 02-07-2013, 04:32 PM   #6
As long as the box remains accessible, whether fro the room or the attic you are fine. You cannot bury live wires.
Old 02-08-2013, 08:42 AM   #7
Rewards Points: 2,516
Do you know whether power for these 2 fans comes into either:
-the fan you want to remove locaton( like 5th diagram below)
-the fan you want to keep location(also could be like 5th diagram below)
-the switch location( like 2nd and 4th diagrams below)
-a separate junction box which then feed the switch then back to j-box then out to fans(like the 1st and 3rd diagrams below)
hammerlane is offline   Reply With Quote
Old 02-08-2013, 08:56 AM   #8
here are some various setups of how your wiring could be...diagrams I had saved so I didnt change the devices. Im sure you could picture a ceiling fan instead of lites or attic fans.
ground wires not show for ease of drawing
Removing one of two fans on one switch...-fans-switch-j-box.jpg   Removing one of two fans on one switch...-2-lites-daisy-chained.jpg   Removing one of two fans on one switch...-fans-switch-j-box-daisy-chained.jpg   Removing one of two fans on one switch...-power-switch-botyh-lites-switch-locale.jpg   Removing one of two fans on one switch...-powr-light-switch-then-2nd-light-always-.jpg
Old 02-08-2013, 10:02 AM   #9
Electrical Enthusiast
Rewards Points: 504
Hammerline: I like the "Capped neutral for code police" on the last diagram.
However, couldn't you just run 2-wire cable and recode the white as hot? Or is there a problem with not having a neutral in the box?
Kyle_in_rure is offline   Reply With Quote
Old 02-08-2013, 10:08 AM   #10
You could use XX-2 cable which would basically be a switch loop but new codes require a neutral at switch locations in case later you automate or use a switch which requires a neutral like some timer switches or motion switches.
if it was me and I knew I'd never have nothing there but a single pole switch---screw it Im running XX-2 cable
Old 02-08-2013, 10:18 AM   #11
Rewards Points: 504
I guess that's bad news for a lot of older houses where ALL the switches are switch-loops.
Old 02-08-2013, 10:28 AM   #12
The new code requirement would apply to new builds and certain remodels
Old 02-08-2013, 11:59 AM   #13
MarginallyQualified
Which is why Q's about motion sensors and other such modern controls get the "how old is the house" and/or "do you know where the feed for the circuit comes from" responses.
Diagram for 3 way ceiling fan light switch Aurora65 Electrical 22 11-27-2012 10:11 AM
taco sr503-4 switch jmon HVAC 53 11-12-2012 07:26 PM
Light in one lighted three-way switch not working dalepres Electrical 2 06-26-2012 07:27 AM
2 Ceiling fans and 1 double pole switch karpolu Electrical 17 05-28-2012 11:00 AM
removing a combo switch gresoul Electrical 2 02-18-2008 07:36 AM
