-   -   Removing one of two fans on one switch... (http://www.diychatroom.com/f18/removing-one-two-fans-one-switch-171297/)
Huggins90 02-07-2013 12:21 PM
Hey guys,
So I am needing to remove one fan completely and patch the hole. There are two fans in the living area on one switch. If I just disconnect and pull the fan, and patch the hole, is this against code? Will it prevent the other fan from working correctly? How would I go about finding out what I need to know if there are various ways it could have been wired...? Any help would be awesome. Thanks!
-Huggins90
Jim Port 02-07-2013 12:43 PM
Before you can abandon the cables you will need to make sure they are dead and removed from the boxes. You will also need to check that the fan you want to remove does not feed the other fan. If it does you will need to leave the box and install a blank cover. You will not be able to bury that box.
TarheelTerp 02-07-2013 01:50 PM
Originally Posted by Huggins90 (Post 1111656)
So I am (wanting) to remove one fan completely and (think I need to) patch the hole.
Disconnect and remove the fan.
Safe the wire. (wirenuts in the box .
Install a blank cover.
Huggins90 02-07-2013 02:49 PM
Ha thanks for the edit tarheeltwerp...er uh...terp. So if the fan feeds the other fan, and I safe the wires and install the blank cover, the cover would still be visible? It mounts externally? Could I pull the box, then connect the wires back together in the attic in a junction box?
TarheelTerp 02-07-2013 03:24 PM
Originally Posted by Huggins90 (Post 1111741)
...the cover would still be visible? It mounts externally?
You can do almost anything you like...
I suggest using the $5 and 30 seconds til done approach.
Jim Port 02-07-2013 03:32 PM
As long as the box remains accessible, whether fro the room or the attic you are fine. You cannot bury live wires.
hammerlane 02-08-2013 07:42 AM
Do you know whether power for these 2 fans comes into either:
-the fan you want to remove locaton( like 5th diagram below)
-the fan you want to keep location(also could be like 5th diagram below)
-the switch location( like 2nd and 4th diagrams below)
-a separate junction box which then feed the switch then back to j-box then out to fans(like the 1st and 3rd diagrams below)
hammerlane 02-08-2013 07:56 AM
5 Attachment(s)
here are some various setups of how your wiring could be...diagrams I had saved so I didnt change the devices. Im sure you could picture a ceiling fan instead of lites or attic fans.
ground wires not show for ease of drawing
Kyle_in_rure 02-08-2013 09:02 AM
Hammerline: I like the "Capped neutral for code police" on the last diagram.:laughing:
However, couldn't you just run 2-wire cable and recode the white as hot? Or is there a problem with not having a neutral in the box?
hammerlane 02-08-2013 09:08 AM
You could use XX-2 cable which would basically be a switch loop but new codes require a neutral at switch locations in case later you automate or use a switch which requires a neutral like some timer switches or motion switches.
if it was me and I knew I'd never have nothing there but a single pole switch---screw it Im running XX-2 cable
Kyle_in_rure 02-08-2013 09:18 AM
I guess that's bad news for a lot of older houses where ALL the switches are switch-loops.
hammerlane 02-08-2013 09:28 AM
The new code requirement would apply to new builds and certain remodels
TarheelTerp 02-08-2013 10:59 AM
Which is why Q's about motion sensors and other such modern controls get the "how old is the house" and/or "do you know where the feed for the circuit comes from" responses.
