Removing One Switch From A Three Gang Box - Electrical - DIY Chatroom Home Improvement Forum
Old 12-19-2012, 09:35 PM   #1
Removing one switch from a three gang box
I have three lights switches in one box. The middle switch is basically a filler switch. I still to this day flip the dead switch trying to turn lights on. My question is, do they make a filler plate, or some sort of cover plate that is long enough but with one less hole. I can remove the switch, or even move the dead switch to one of the ends if that would help. I would rather not cut drywall and put a double gang box in.
paintdrying is offline   Reply With Quote
Old 12-19-2012, 09:46 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,252
Get a 3 gang plate for 2 toggle switches and a receptacle. Replace the dead switch with a receptacle. Very handy for plugging in the vacuum cleaner.
Coastal South Carolina
Old 12-20-2012, 09:00 AM   #3
Rewards Points: 14,290
Lowes and HD both have a moduler system where you can make up almost and configuration. The pieces just snap together.
Old 12-20-2012, 10:50 AM   #4
A "Handy Husband"
rjniles's Avatar
But they look like crap
The Following User Says Thank You to rjniles For This Useful Post:
TTW (12-20-2012)
Old 12-20-2012, 11:37 AM   #5
Oso954's Avatar
Rewards Points: 1,610
The blank adapter for a toggle switch does exist, but you probably won't find it locally unless it is an electrical supply house. Online, even Amazon has them.
http://www.amazon.com/Leviton-80700-.../dp/B003ATZR6U
Oso954 is online now   Reply With Quote
Old 12-20-2012, 01:03 PM   #6
Engineer
Rewards Points: 161
The OP would need to verify a neutral was present (or run one) to accomplish this one.
diystephen is offline   Reply With Quote
The Following User Says Thank You to diystephen For This Useful Post:
rjniles (12-20-2012)
Old 12-20-2012, 03:19 PM   #7
I found one of these at Home Depot for a lot less than the Amazon price. We had a similar setup where third switch was for a second outdoor light that was removed.
brgmgb is offline   Reply With Quote
Old 12-20-2012, 08:52 PM   #8
I will consider an outlet. I checked the big box but could not find anything. I would rather just go to an electrical suppy house. No patience for bigbox stores with no one around, and no one that even knows anything.
Light in one lighted three-way switch not working dalepres Electrical 2 06-26-2012 06:27 AM
Converting switch to switch & constant power outlet BCeagle08 Electrical 4 01-29-2012 09:34 PM
hard to fit duplex switch and dimmer in 2 gang. please help fabian Electrical 9 01-18-2010 07:54 AM
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
3 gang switch or 3 way switch ?? explain with schematics vivek1406 Electrical 7 10-02-2008 05:54 PM
