Old 08-19-2010, 04:27 PM   #1
sjk
Removing old light fixture & install ceiling fan
I removed an old light fixture in my kitchen to install a ceiling fan. When I removed the old light fixture, it had a black wire connected to the black wire from the ceiling & the white wire was connected to 2 other wires from the ceiling. I could not tell if there was a ground wire connected to the light fixture anywhere. I have an older home & the wires have the old coating that make the wires look black. I pay very close attention when removing the old fixtures so that I can re-connect the proper wires. My new ceiling fan has a ground wire on the ceiling plate & a ground wire in the motor. If I re-connect the white wire from the new ceiling fan to the two wires that were connected to the old light fixture's white wires, will the new fan work correctly?
sjk is offline   Reply With Quote
Old 08-19-2010, 08:42 PM   #2
joed's Avatar
It should. connect the white the two wires and the black to the single black wire. If there is a ground wire connect it to the green or bare wire in the box. If the box is metal you can connect the ground to the ground screw in the bottom of the box.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 08-19-2010, 09:12 PM   #3
Electrician
Proby's Avatar
Remember that you need to hang a fan from a fan rated box. You can't just install a fan on a typical octagon box made for a ceiling fixture.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 04-17-2011, 09:32 AM   #4
Well that depends. I have a house built in 1917. Connect the white to the white, the black to the black and ground to ground right? I had to use an electric meter to find the hot wire. I actually had to connect the black to the white and vice versa. Colors in old houses mean nothing especially if they are all black which mine have been too so invest in somthing to tell you what the hot wire is or ouch!
eokhuijzen is offline   Reply With Quote
Problems Installing a Light Fixture onto a Ceiling Fan adk97 Electrical 4 08-16-2010 06:30 AM
Trying to install a new ceiling light in an old house Yikes Electrical 2 07-26-2010 12:49 AM
Old house, having light fixture issues atomiclilly Electrical 6 12-03-2009 09:54 AM
Problem with 5 light ceiling fan fixture wetsu Electrical 2 06-05-2009 09:22 PM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 07:22 AM
