Removing Old Flex Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 08-31-2010, 05:50 PM   #1
Rewards Points: 91
removing old flex conduit
Guys, I just pulled all the walls out of a room to put in new drywall. Underneath the old, I've found several long runs of very old thick metal flex conduit. The conduit and boxes it's connected to are all empty. I'd like to remove it all before i insulate and drywall, any tips for removal? It seems very strong and stiff. Below is a pic if it's helpful.
thanks!
Matt
mmhendrie is offline   Reply With Quote
Old 08-31-2010, 05:53 PM   #2
Licensed electrician
Rewards Points: 1,276
If you are sure it is not needed and is verified as dead, I would use a sawzall to cut it out.
Old 08-31-2010, 06:10 PM   #3
Rewards Points: 324
looks like you need to put more outletts.i would find out if it goes back to main panel.if so pull in another ckt or two before you cover it up.also add lites and sw's.
oleguy74 is offline   Reply With Quote
PVC conduit - custom offset or bending tns1 Electrical 25 08-29-2011 06:56 PM
Warm and Noisy Electrical Conduit Intravartolo Electrical 4 07-26-2010 02:46 AM
Flex Conduit for LV or coax? tonyBagadonuts Electrical 9 03-23-2010 11:08 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 07:49 PM
What should I use to sexure flex conduit... rgsgww Electrical 19 03-20-2009 01:37 PM
