removing old box
1 Attachment(s)
I'm trying to figure out how to remove an old (1940s) box while minimizing damage to the (lath and plaster) wall. The box is attached to the wall firmly, but there aren't any screws inside the box, except for the tips of two screws pointed INTO the box. I'd like to know exactly how the box is attached so as to get a better idea of how to remove it.
Looks like the plaster has a grip on it. If it were mine I wouldn't worry so much about minimizing damage. Are you replacing or removing the box? If removing you'll still have a patch.
I'd like to take the box out just to get a feel for how hard it would be to fish new wire through the wall (to replace knob and tube). The box must have some kind of flaps or ears on it. It's definitely not being held just by the plaster.
Duplicate
Duplicate
Yep you'll need to remove more plaster and probably lath.
I wonder if the screws coming in from each side are actually for adjusting flaps, and the flaps are attached to braces which are attached to the studs.
You would typically be dealing with a box that looks similar to this. http://www.hubbellcatalog.com/raco/i...Boxes/0574.jpg The screw tip you see holds a bracket on. It does not hold the box in the wall. You will need to slide a hacksaw blade next to the stud and cut the nails.
I had a box in my house that looked like your box from the outside but was mounted like this: http://www.garvinindustries.com/Elec...uts/54181-TBAR That was a pain to get out.
Others were nailed to the stud side, while some were nailed to the front of the stud like this: http://www.garvinindustries.com/Elec...ackets/52151-B I've had good success with a reciprocating saw held near but not on the wall. But still might be too much vibration for plaster and lathe (I have plaster over drywall). Also see this thread: http://www.diychatroom.com/f18/runni...r-lathe-59376/ RST |
3 Attachment(s)
I finally got the box out. It turned out to have two ears, which were not visible at first because they were covered with lath. I removed the lath with a chisel. The box was held by one screw on each side.
they cheated when they installed that box:no: it would not be allowed today
every box in my house was installed the same way, except vertically instead of sideways
That is how pretty much every box like that, of that era, is installed.
Many had metal rails that the box ears were slid into, and the rails nailed to the studs on each side. Quote:
| All times are GMT -4. The time now is 11:48 AM. |
