Removing A Light Source From A 3 Way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 11-29-2009, 02:51 AM   #1
Removing a light source from a 3 way switch
HELP... Please... We wired our lights for the stairs together on a 3 way switch. However, it wasnt until the walls were completed, painted and finished that I realized it was all wrong. The light at the bottom of the stairs should be on a single light switch and the light at the top of the stairs should stay on the 3 way light switch as is. Is there a way we can seperate them without completely riping apart the walls? Although its not a HUGE deal... I absolutely HATE that the front door cant be lit up without the light in front of the bedrooms being on as well.. please please please help
ecsedlak is offline   Reply With Quote
Old 11-29-2009, 04:02 AM   #2
Hi.
Sorry, but your post does not make too much sense, as written. Can you provide more information?
Do you have double gang boxes at the top/bottom of the stairs; or is it just one switch on top and two switches at bottom, or vice versa?
Do you know where your light legs are?
Do you know where your hot legs are?
Your post is very vague. Is this one light with two 3 way switches, or 2 or 3 different light legs with several switches all together in a double/triple gang box?
Also, it sucks when it happens, but ripping up a wall/ceiling to rewire is not that big a deal, but it will cost a couple/few hundred bucks.
Good luck.
Timster is offline   Reply With Quote
Old 11-29-2009, 08:32 AM   #3
Rewards Points: 1,442
Do you remember where (which switch box or light fixture box) the power feed comes in?
AllanJ is online now   Reply With Quote
Old 11-29-2009, 09:17 AM   #4
I have a cheap solution for you.
Take the bulb out of the bottom fixture and buy a floor lamp.
pyper is offline   Reply With Quote
Old 11-29-2009, 11:46 AM   #5
joed's Avatar
Rewards Points: 11,990
There might be a way to do. If you tell us how the cable are currently run between the switches and the fixtures we can can assist you.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 05:28 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 10:02 AM
HowTo: Adding two exterior lights + switch, piggyback new switch off existing switch? ghost Electrical 14 04-19-2009 06:04 PM
Tracing light switch to an outlet allanet Electrical 13 04-03-2009 09:44 AM
Problem changing light switch grgryl Electrical 14 08-10-2008 02:26 PM
