Removing Lamp Holder - Electrical - DIY Chatroom Home Improvement Forum
Old 04-04-2013, 07:24 AM   #1
Send a message via AIM to Rich Send a message via Yahoo to Rich
Removing lamp holder
We have two of these brass over porcelain lamp holders. I would like to remove them without destroying the brass but I can't figure out how to get the switch (the key, I think) pulled out so the brass cover comes off to get to the screws. Anyone seen these or similar? Should the key just pull out, screwout or is there some trick to it normally. Any input is appreciated.
Removing lamp holder-brass_lamp_holder_1.jpg   Removing lamp holder-brass_lamp_holder_2.jpg
Rich is offline   Reply With Quote
Old 04-04-2013, 07:29 AM   #2
if you notice that the switch doesn't go through a hole it is a slot. i think the out sleeve around the socket slides off.
Old 04-04-2013, 07:33 AM   #3
Rewards Points: 13,712
Try turning a few times in the counter clockwise direction to see if it unscrews.
Old 04-04-2013, 08:23 AM   #4
I can't get to the one right now but the other that looks the same but has "H&K" on the switch I can't do either things mentioned. Turned counter clockwise a few times and it just clicks without coming out any. Pulling on the socket brass doesn't seem to do anything. Any other suggestions.
Old 04-04-2013, 08:29 AM   #5
I'd guess the knob is on a spline and can be pulled straight out.
Old 04-04-2013, 09:23 AM   #6
With how much force? I've pulled on it some but haven't gotten it to move.
Old 04-04-2013, 09:41 PM   #7
TTW
TTW's Avatar
This is my vote, the lower brass part around the threaded insert should pull off straight down, may need to wiggle, tilt and twist some.
Make sure the entire circuit is off at the breaker first!
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Patio Post Lamp Wiring Perry401 Electrical 2 06-08-2011 04:21 PM
Help with ceramic lamp holder cwp1979 Electrical 4 08-29-2010 07:34 PM
Converting a ceiling lamp holder to a grounded outlet koz Electrical 2 12-30-2009 06:24 AM
Please Help with Outdoor Lamp/ Sensor hcjoak09 Electrical 2 12-16-2009 10:49 PM
