Removing A Gang Box Without Tearing Up Surrounding Drywall - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-24-2013, 11:21 AM   #16
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Stop calling it a gang box. It's a recept box or a switch box. If there are multiple devices in the box it's a 2 gang switch box, 3 gang switch box....
The Following 2 Users Say Thank You to k_buz For This Useful Post:
chuck2112 (10-25-2013), gregzoll (10-24-2013)
Old 10-24-2013, 01:44 PM   #17
Licensed electrician
Rewards Points: 1,750
You are not allowed by the electric code to have lighting on the dining room receptacle circuit.
Old 10-24-2013, 01:52 PM   #18
Rewards Points: 348
Even if that lighting is not actually in the dining room?
herdfan is offline   Reply With Quote
Old 10-24-2013, 02:16 PM   #19
No lighting, regardless of location.
plummen (10-24-2013)
Old 10-24-2013, 06:42 PM   #20
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
A gangbox is a place to dump tools at the end of the day ,A single/2/3 or 4 gang box is for wiring.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
Old 10-25-2013, 08:36 AM   #21
That's good to know. I'll check my local code for more info. But it doesn't make much sense to me since the lighting would be an "add-on" outside.
chuck2112 is offline   Reply With Quote
Old 10-25-2013, 09:01 AM   #22
Those circuits typically also power the kitchen receptacles where large draw appliances like coffee makers and toasters are used.
plummen (10-25-2013)
Old 10-25-2013, 09:39 AM   #23
Rewards Points: 1,476
Here's a thought that might help, but might look a little silly. If you convert your 1 gang box to a two gang box it will make it easy to remove it.
You just cut the existing hole wide enough to fit in a 2 gang old work box(make sure you know what side the stud is on). You'll now have access to the nails holding the box to the stud and can pull them out with pliers. Install the two gang old work box and either add another receptacle so you can plug in 4 devices or use one of those hybrid covers that have a phone or cable jack on the other side. You might not love it, but guests aren't likely to think twice about it.
This will also give you a huge hole to work with for fishing through the wall.
mikegp is offline   Reply With Quote
Old 10-25-2013, 01:33 PM   #24
Rewards Points: 6,652
Dining should not, since it should be on its own circuit, that would also feed the baseboard outlets in the Kitchen (ie gas stove 120 can be on this circuit).
If the person who did the circuit design did it correct, they would have made it so that you could pull a future circuit later. Now of course, if the OP would be able to pull from the circuit that feeds the front doorway lighting, or garage lighting if attached, vs. pulling a single feed from the panel to feed this lighting circuit.
My backdoor entry along with outside lighting, comes off of the same circuit that feeds the Kitchen lighting. Front entry & front door outside comes off of the Living room outlet & ceiling lighting circuit. This is due to how it was done back in the day. Even today, you run into where the lighting for outdoors is setup the same way, or feeds off of the outdoor outlet circuit, that has a gfci on it.
Old 10-25-2013, 01:35 PM   #25
Mikegp, finding someone with small hands usually helps, in having them grab the wire as it is pulled down with fish sticks. I always tear mine up, when trying to reach into a single gang cutout. Looks like I have been fighting with the family cat, when I get done.
Old 10-25-2013, 07:30 PM   #26
plummen's Avatar
Thats why Ive always run seperate circuits for every room,I still run a seperate lighting circuit for the kitchen and another for dining room lights though since I always run 20a circuits for all kitchen and dining circuits independent from each other of course.
removing drywall and when to stop artee gee Drywall & Plaster 3 12-05-2012 08:45 PM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 08:15 PM
Drywall over 2 gang electrical box that has dead circuit? wbc Electrical 3 10-10-2011 08:29 AM
Removing Drywall for Repairs BJH Drywall & Plaster 22 01-29-2011 02:22 AM
Removing drywall dust after sanding? ponchoman1 Painting 6 10-13-2006 07:33 PM
