Removing Fan From Single Switch In Bathroom - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-03-2011, 08:50 PM   #16
Rewards Points: 582
yes but you still to make sure that one bottom wire is hot...and make sure other 2 are fan and light.......again separate one at time or use meter...
Old 12-03-2011, 08:54 PM   #17
Okay JBFan, then can you offer more insight based in the additional two pictures of inside the box? Do I have the extra wire I need?
SGS1965 is offline   Reply With Quote
Old 12-03-2011, 08:56 PM   #18
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Same thing I stated in my first post.
Old 12-03-2011, 09:07 PM   #19
Rewards Points: 582
we need to see if bottom wire in box is power...need to see if wires on top in box 1=fan 1=light 2=nuetural
Old 12-03-2011, 09:10 PM   #20
Rewards Points: 6,652
Man, some painters should be shot. Is there any way that you can clean up the paint off of the wiring, so that the colors of the jackets are better seen. You should be able to wipe with rubbing alcohol after you shut power off to that circuit, or just rub with a old wash cloth, and the paint should somewhat come off. For the ground, you may have to scrape a little with a razor blade, or edge of a screwdriver.
The Following User Says Thank You to gregzoll For This Useful Post:
ben's plumbing (12-03-2011)
Old 12-03-2011, 09:16 PM   #21
jbfan's Avatar
Rewards Points: 650
Where is the missing switch that other black wire went to?
Tags
fan , switch
Re-wire dual pole switch to single pole bujaman Electrical 3 05-31-2011 06:09 AM
single pole switch for jacuzzi tub kodeblue Electrical 6 09-19-2009 11:48 AM
HELP.. trouble adding light to single pole switch RickDel Electrical 13 09-09-2009 10:18 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Replacing a single switch with 3 way switch using old wiring chriscam75 Electrical 3 02-17-2009 08:15 PM
