Removing Fan From Single Switch In Bathroom - Electrical - DIY Chatroom Home Improvement Forum
Old 12-03-2011, 09:14 AM   #1
Removing Fan From Single Switch in Bathroom
I have a single switch when tripped turns on the lights and a fan. I want to change this so I have two switches: one to turn on the lights and the other to turn on the fan. How do I do this?
SGS1965 is offline   Reply With Quote
Old 12-03-2011, 09:22 AM   #2
Rewards Points: 6,652
You would have to run 14/3 from the switch box to the ceiling light and fan. Only works that way, if power first comes into the switch box.
Old 12-03-2011, 09:33 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
IS this a fan light combo unit? or separate light and fan unit?
What wires are in the switch box now?
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 12-03-2011, 10:14 AM   #4
It is a separate light and fan unit. There are currently three wires attached to a single up and down walls switch.
Old 12-03-2011, 10:29 AM   #5
Are they Red & Black on one screw, and Black on the other of the switch, or two blacks and a bare copper? Post a picture.
Old 12-03-2011, 07:54 PM   #6
Here's a picture.
Thanks for your help.
Old 12-03-2011, 08:10 PM   #7
Can you post a picture looking into that box, and also please put up a wiring diagram showing how the wiring runs. Unless you have power going into that box (ie 14/2), and load going out (14/2), that means that up at the fan/light unit, they have the black & blue tied to the black coming from the switch. The hard part would be pulling 14/3 from the switch box to the ceiling fan, if the wires are stapled in the wall.
Can you access the light/fan unit from up above, or is that another floor above that bath?
Old 12-03-2011, 08:19 PM   #8
Rewards Points: 582
it looks to me that bottom wire is hot leg to switch...top wires one to fan one to light...separate these two top and touch them one at a time to power source if they are separate change to double switch ...job done....
Old 12-03-2011, 08:25 PM   #9
What's a double switch? What does that look like? I had originally bought two single pole switches. Can I use these or is a double switch something different? If I can use these I am not sure how I get power to the other switch.
Old 12-03-2011, 08:29 PM   #10
Rewards Points: 582
you should already have power on the bottom screw....i think...a double switch looks like a double plug only switches sorry haven't learned to post pictures..
Old 12-03-2011, 08:31 PM   #11
Rewards Points: 582
double switch allowes you to control 2-fixtures out of a single box...
Old 12-03-2011, 08:36 PM   #12
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
The bottom wire is the switch leg.
The two top wires are the power in and power out.
You do not have a way to do what you want without getting another wire from the switch to the fan.
jbfan is online now   Reply With Quote
Old 12-03-2011, 08:42 PM   #13
Rewards Points: 582
get picture of inside box with the rest of the wires...
Old 12-03-2011, 08:44 PM   #14
Thanks for your help. I'll go exchange my two singe switches for one double switch. I'm assuming that the reason I need a double switch is because I only have one hot lead and that is all a double switch will require, correct?
Thanks again.
Old 12-03-2011, 08:47 PM   #15
jbfan's Avatar
Rewards Points: 386
Thanks again.
That will not do anything for you.
You can't do what you want without another wire.
Tags
fan , switch
Re-wire dual pole switch to single pole bujaman Electrical 3 05-31-2011 06:09 AM
single pole switch for jacuzzi tub kodeblue Electrical 6 09-19-2009 11:48 AM
HELP.. trouble adding light to single pole switch RickDel Electrical 13 09-09-2009 10:18 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Replacing a single switch with 3 way switch using old wiring chriscam75 Electrical 3 02-17-2009 08:15 PM
