-   -   Removing Fan From Single Switch in Bathroom (http://www.diychatroom.com/f18/removing-fan-single-switch-bathroom-125431/)
SGS1965 12-03-2011 10:14 AM
I have a single switch when tripped turns on the lights and a fan. I want to change this so I have two switches: one to turn on the lights and the other to turn on the fan. How do I do this?
gregzoll 12-03-2011 10:22 AM
You would have to run 14/3 from the switch box to the ceiling light and fan. Only works that way, if power first comes into the switch box.
rjniles 12-03-2011 10:33 AM
IS this a fan light combo unit? or separate light and fan unit?
What wires are in the switch box now?
SGS1965 12-03-2011 11:14 AM
It is a separate light and fan unit. There are currently three wires attached to a single up and down walls switch.
gregzoll 12-03-2011 11:29 AM
Are they Red & Black on one screw, and Black on the other of the switch, or two blacks and a bare copper? Post a picture.
SGS1965 12-03-2011 08:54 PM
1 Attachment(s)
Here's a picture.
Attachment 41974
Thanks for your help.
gregzoll 12-03-2011 09:10 PM
Can you post a picture looking into that box, and also please put up a wiring diagram showing how the wiring runs. Unless you have power going into that box (ie 14/2), and load going out (14/2), that means that up at the fan/light unit, they have the black & blue tied to the black coming from the switch. The hard part would be pulling 14/3 from the switch box to the ceiling fan, if the wires are stapled in the wall.
Can you access the light/fan unit from up above, or is that another floor above that bath?
ben's plumbing 12-03-2011 09:19 PM
it looks to me that bottom wire is hot leg to switch...top wires one to fan one to light...separate these two top and touch them one at a time to power source if they are separate change to double switch ...job done....
SGS1965 12-03-2011 09:25 PM
What's a double switch? What does that look like? I had originally bought two single pole switches. Can I use these or is a double switch something different? If I can use these I am not sure how I get power to the other switch.
ben's plumbing 12-03-2011 09:29 PM
you should already have power on the bottom screw....i think...a double switch looks like a double plug only switches sorry haven't learned to post pictures..
ben's plumbing 12-03-2011 09:31 PM
double switch allowes you to control 2-fixtures out of a single box...
jbfan 12-03-2011 09:36 PM
The bottom wire is the switch leg.
The two top wires are the power in and power out.
You do not have a way to do what you want without getting another wire from the switch to the fan.
ben's plumbing 12-03-2011 09:42 PM
get picture of inside box with the rest of the wires...
SGS1965 12-03-2011 09:44 PM
Thanks for your help. I'll go exchange my two singe switches for one double switch. I'm assuming that the reason I need a double switch is because I only have one hot lead and that is all a double switch will require, correct?
Thanks again.
jbfan 12-03-2011 09:47 PM
Thanks again.
That will not do anything for you.
You can't do what you want without another wire.
