Removing An End Of The Line Outlet From The Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 08-28-2012, 04:38 PM   #1
Rewards Points: 32
Removing an end of the line outlet from the light switch
Hi:
I have an outlet that is connected to a light switch and would like to remove it from the switch so that it is hot constantly. I have looked at the switch and the outlet and it appears that the source comes through the light on the ceiling to the switch and the outlet. Those are the only three things on that line. Is there some way I can make the outlet work without the switch being on?
lovetobuild is offline   Reply With Quote
Old 08-28-2012, 04:59 PM   #2
Rewards Points: 2,516
Take wires at switch---wires A and B and wire nut together. Depending on whether your source power is at the Switch location(diagram "current 1) or at the Outlet location(diagram current 2) you have one of the 2 setup shown below
Removing an end of the line outlet from the light switch-switch-control-utlet-source-outlet.jpg   Removing an end of the line outlet from the light switch-switch-control-utlet-source-switch.jpg
hammerlane is offline   Reply With Quote
Old 08-28-2012, 05:03 PM   #3
In both diagrams below, the switch is not used. The outlet is constantly HOT
Removing an end of the line outlet from the light switch-switch-control-utlet-source-switch..switch-not-used.jpg   Removing an end of the line outlet from the light switch-switch-control-utlet-source-outlet...3.jpg
Old 08-28-2012, 05:04 PM   #4
you should be able to take the 2 wires off of the switch and wire nut them together thus bypassing the switch and making the outlet hot all the time.
Old 08-28-2012, 08:13 PM   #5
Rewards Points: 32
Thank you hammerlane and DannyT. I appreciate your input....there is one thing, I still need the switch to control the light...(where the source is coming). So, I can't bypass the switch completely. Hammerlane...in the diagram where you put the two black on the switch and nut together the two white....will that still control the light? Right now...coming from the light...into the switch....there are two black and two white...one black and one white go to the switch and the other black and white are nutted together. At the outlet...only one black and white come in and they are connected to the outlet. Let me know what you think and thank you so much for taking the time for me.
Old 08-28-2012, 08:24 PM   #6
No in this diagram the switch is controlling the receptacle.
Are you saying in your setup that one switch controlled a receptacle AND a light fixture?
Removing an end of the line outlet from the light switch-switch-20control-20utlet-20source-20at-20switch.jpg
Old 08-28-2012, 08:26 PM   #7
provide a diagram of your setup
Old 08-28-2012, 10:03 PM   #8
Rewards Points: 32
The switch I have, controls a light on the ceiling and the outlet. The source (I believe) is coming from the light on the ceiling. In the switch and outlet...this is what I see.
Old 08-29-2012, 08:22 PM   #9
Rewards Points: 32
this is the point that I am at right now....hoping someone can give their input ....I don't know if hammerlane is around tonight or not......thank you for the help that I have received so far......
Old 08-30-2012, 07:50 PM   #10
Rochsolid's Avatar
Hi:
Isn't a switch plug?(does the light switch control the plug)
If your power comes from the light to your switch, that is called a "switch leg" and if that is the case, you would need a 3 wire from your light to your switch to continue the power to your plug. If there is no 3 wire from your light to your switch then your plug would not have a proper neutral, because your neutral "white" wire at your switch is not a neutral, it's a hot.
Rochsolid is offline   Reply With Quote
Old 08-31-2012, 04:00 PM   #11
Rewards Points: 32
Thank you Rocksolid.....I really did wonder how I would be able to do this when I saw only the two black and white wires in the switch. I guess I will just have to keep it as it is....I really appreciate all of your help. You guys in DIY are wonderful.
Thanks so much
Old 09-02-2012, 11:37 AM   #12
Rochsolid's Avatar
Thanks so much
Your welcome, glad I could be of help
Old 09-02-2012, 11:59 AM   #13
If it's free...It's me
There has to be something else. With what is provided, it looks to me like there is no neutral conductor at the receptacle, but this would continually trip the breaker. Do any of the white conductors have black tape or some black coloring to designate that they are hot? Also, can you provide a diagram of what you have at the light?
Johnny'sHotDogs is offline   Reply With Quote
Old 09-02-2012, 12:07 PM   #14
Rochsolid's Avatar
Thanks so much
Wiring an outlet to a switch, to a light Athens Electrical 5 01-04-2012 07:03 PM
How to disconnect an outlet from a light switch mattjarvinen Electrical 2 08-25-2011 11:53 PM
Changing 2 way switch to control light, not outlet? andysam Electrical 0 05-30-2011 09:20 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 01:23 PM
