-   -   Removing an end of the line outlet from the light switch (http://www.diychatroom.com/f18/removing-end-line-outlet-light-switch-155136/)
lovetobuild 08-28-2012 05:38 PM
Hi:
I have an outlet that is connected to a light switch and would like to remove it from the switch so that it is hot constantly. I have looked at the switch and the outlet and it appears that the source comes through the light on the ceiling to the switch and the outlet. Those are the only three things on that line. Is there some way I can make the outlet work without the switch being on?
hammerlane 08-28-2012 05:59 PM
2 Attachment(s)
Take wires at switch---wires A and B and wire nut together. Depending on whether your source power is at the Switch location(diagram "current 1) or at the Outlet location(diagram current 2) you have one of the 2 setup shown below
hammerlane 08-28-2012 06:03 PM
2 Attachment(s)
In both diagrams below, the switch is not used. The outlet is constantly HOT
DannyT 08-28-2012 06:04 PM
you should be able to take the 2 wires off of the switch and wire nut them together thus bypassing the switch and making the outlet hot all the time.
lovetobuild 08-28-2012 09:13 PM
Thank you hammerlane and DannyT. I appreciate your input....there is one thing, I still need the switch to control the light...(where the source is coming). So, I can't bypass the switch completely. Hammerlane...in the diagram where you put the two black on the switch and nut together the two white....will that still control the light? Right now...coming from the light...into the switch....there are two black and two white...one black and one white go to the switch and the other black and white are nutted together. At the outlet...only one black and white come in and they are connected to the outlet. Let me know what you think and thank you so much for taking the time for me.
hammerlane 08-28-2012 09:24 PM
1 Attachment(s)
No in this diagram the switch is controlling the receptacle.
Are you saying in your setup that one switch controlled a receptacle AND a light fixture?
hammerlane 08-28-2012 09:26 PM
provide a diagram of your setup
lovetobuild 08-28-2012 11:03 PM
1 Attachment(s)
The switch I have, controls a light on the ceiling and the outlet. The source (I believe) is coming from the light on the ceiling. In the switch and outlet...this is what I see.
lovetobuild 08-29-2012 09:22 PM
this is the point that I am at right now....hoping someone can give their input ....I don't know if hammerlane is around tonight or not......thank you for the help that I have received so far......
Rochsolid 08-30-2012 08:50 PM
Hi:
Isn't a switch plug?(does the light switch control the plug)
If your power comes from the light to your switch, that is called a "switch leg" and if that is the case, you would need a 3 wire from your light to your switch to continue the power to your plug. If there is no 3 wire from your light to your switch then your plug would not have a proper neutral, because your neutral "white" wire at your switch is not a neutral, it's a hot.
lovetobuild 08-31-2012 05:00 PM
Thank you Rocksolid.....I really did wonder how I would be able to do this when I saw only the two black and white wires in the switch. I guess I will just have to keep it as it is....I really appreciate all of your help. You guys in DIY are wonderful.
Thanks so much
Rochsolid 09-02-2012 12:37 PM
Thanks so much
Your welcome, glad I could be of help
Johnny'sHotDogs 09-02-2012 12:59 PM
There has to be something else. With what is provided, it looks to me like there is no neutral conductor at the receptacle, but this would continually trip the breaker. Do any of the white conductors have black tape or some black coloring to designate that they are hot? Also, can you provide a diagram of what you have at the light?
Rochsolid 09-02-2012 01:07 PM
Thanks so much
