Removing Electric Wall Heaters - Electrical - DIY Chatroom Home Improvement Forum
Old 10-22-2007, 01:30 PM   #1
Question
Removing Electric Wall heaters
I have install central heating and want to remove these old, ugly electric wall heaters from my walls. I was wondering what the best way to go about doing this. Since these are already wired to the panel, can I just install electric outlets where the heaters are so I don't have live wires in my walls?
Each of the electric heaters has it's own on/off switch so there are no thermostats connected to any of them.
jskillet is offline   Reply With Quote
Old 10-22-2007, 03:28 PM   #2
Electrician philosopher
Are they 120V. Or are they 220V?????
Andy in ATL is offline   Reply With Quote
Old 10-22-2007, 04:01 PM   #3
How can I tell? I have no idea. Each unit is pretty small. probably 14in by 8in.
Old 10-22-2007, 04:52 PM   #4
Electrician
Rewards Points: 802
When you say they each have there own off and on switch I am assumeing you mean a breaker for each one. If I am wrong please correct me.
If I were you i would take that wire off the breaker and out of the panel and follow it back as far as you can and cut it off. You don't want someone to be able to come along and rehook it up. Then you can push those wires in the wall and patch the hole.
darren is offline   Reply With Quote
Old 10-23-2007, 08:37 AM   #5
Rewards Points: 264
Just grab the wires, small shock = 120, big zap = 220. TOTALLY KIDDING, do not do that.
Clear up the "own on/off switch" bc my assumption was you mean on the unit, not in the panel. Are they in series or do they each have their own breaker? What size breakers do they plug into? You can always go buy a cheap voltage tester and it will help you. They have 2 prongs, touch one to white and one to black, the meter reads the voltage.
If they're 120 and you want extra outlets, I see no reason you could not wire them in and put a face plate over. If they're 220 or if you don't want the outlets, like Darren said, cut the wires back from the panel and patch the wall holes. Unless you have a few extra dryers, A/C units, or stoves you need plugged in, 220 won't be very useful.
moneymgmt is offline   Reply With Quote
Old 10-23-2007, 08:59 AM   #6
Rewards Points: 1,910
Seriously consider getting an electrician in to trace back the circuits and remove them from the main service panel. No disrespect intended but if you cannot tell if they are 120 or 240 you really should not be messing with this. There are many other things you need to know for your own safety and you probably don't have this knowledge if you cannot tell 120 vs 240.
If you really want outlets there the electrician could easily hook them up whether they are 120 or 240 currently but he might have to change out the breakers because they might be rated for higher amperage than whatever duplex receptical you have installed.
You might also have other loads on these circuits besides the wall heaters.
Removing Baseboard Electric Heaters gieriscm Electrical 12 11-12-2007 04:59 PM
Removing a (block) wall - questions Genhawk21 Building & Construction 3 09-08-2007 06:26 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
