Old 12-23-2010, 05:43 PM   #1
Removing difficult light trim
The recessed lighting trim used in my home has 3 clips that contact the inner surface of the can (see photo). The only way I've found to reliably remove the trim is to destroy it. But, because it is a gimbal or eyeball trim, the bulb can't be changed without removing them! I have about 30 of these so I am getting a little frustrated.
Before I do a wholesale removal (by destruction) & replacement of the trims, are there any good ideas for saving these -- and changing the light bulbs?
thanks,
John
John-wa is offline   Reply With Quote
Old 12-23-2010, 09:16 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Grip the inside of the trim with your finger tips of both hands. Firmly and slowly twist/spin the whole trim while also pulling down.
It will come out without getting destroyed.
Old 12-23-2010, 09:16 PM   #3
Mad Scientist
Will the bulb physically fit through the opening in the existing trim? If it's just a question of not being able to grab the bulb to turn it, try using some kind of suction cup.
As far as removing the trim goes, it probably just takes a steady downward pull and some twisting, but I can see how those clips could be pretty stubborn.
Guess I posted at the same time as Speedy. So yeah, what he said ^^^
McSteve is offline   Reply With Quote
Tags
recessed light, trim
Basic light wiring question speedster1 Electrical 3 11-29-2010 07:48 PM
Removing the old Brady Bunch Kitchen light victor07 Building & Construction 4 11-26-2010 05:42 PM
Recessed Light Trim not flush - tips? sctazmon Electrical 8 10-11-2010 09:20 AM
Removing Paint from old trim josephr33 Painting 3 06-29-2010 03:29 AM
Shower light... what am I missing? Trim won't fit. Alan Electrical 2 10-21-2009 02:13 AM
