Removing A Combo Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 02-18-2008, 05:02 AM   #1
Question
removing a combo switch
a switch was pushed into a light/fan/heater combo switch in the bathroom and i cant seem to be able to open it, there are no visible screws as seen on the image. could you please let me know how it is removed.
gresoul is offline   Reply With Quote
Old 02-18-2008, 06:18 AM   #2
There should be a little slot at the bottom just big enough for a small flat screwdriver to pry the trim ring off. Under that should be screws for the base plate and switch.
jerryh3 is offline   Reply With Quote
Old 02-18-2008, 07:36 AM   #3
Thanks for that ill get on it.
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 06:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
combo switch problem electric1 Electrical 2 06-11-2004 11:11 AM
