removing a combo switch
1 Attachment(s)
a switch was pushed into a light/fan/heater combo switch in the bathroom and i cant seem to be able to open it, there are no visible screws as seen on the image. could you please let me know how it is removed.
Thanks |
There should be a little slot at the bottom just big enough for a small flat screwdriver to pry the trim ring off. Under that should be screws for the base plate and switch.
Thanks for that :thumbsup: ill get on it.
| All times are GMT -4. The time now is 03:42 AM. |
