Removing A Chandelier And Leaving Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 02-01-2014, 10:16 PM   #1
yummy mummy's Avatar
Rewards Points: 1,016
Removing a Chandelier and leaving wires
Hi everyone
I removed a chandelier and do not want to replace with a fixture as the home is being sold.
Is it ok if I tape the ends of the wires with electrical tape and leave them alone?
Is there a safety issue by doing that.
Thank you.
http://diyitnow.blogspot.com
yummy mummy is offline   Reply With Quote
Old 02-01-2014, 10:23 PM   #2
Sparky
Rewards Points: 510
The correct way is wirenuts and a blank cover.
Techy is offline   Reply With Quote
The Following 2 Users Say Thank You to Techy For This Useful Post:
Kyle_in_rure (02-01-2014), plummen (02-01-2014)
Old 02-01-2014, 10:37 PM   #3
Thanks very much Techy. I will put wire nuts on and a cover.
Old 02-04-2014, 06:53 PM   #4
Rewards Points: 266
Why not just install an inexpensive (cheap) light so there is no question that the circuit works?
ionized is offline   Reply With Quote
Old 02-04-2014, 07:02 PM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Why? It was probably addressed in the sale. I've been hired out many times to remove fixtures with no replacements...
The Following User Says Thank You to stickboy1375 For This Useful Post:
jbfan (02-04-2014)
Old 02-05-2014, 04:55 AM   #6
Rewards Points: 712
Code requires a wall switch controlled lighting outlet, so you can't leave the room with nothing.
Mark
busman is offline   Reply With Quote
Old 02-05-2014, 05:24 AM   #7
Licensed electrician
Rewards Points: 1,004
Mark
The outlet will still be there, it just will not have a fixture on it.
stickboy1375 (02-05-2014)
Old 02-05-2014, 06:55 AM   #8
Rewards Points: 712
Jim,
Respectfully, a covered JB does not meet the definition of an outlet. An outlet is, "A point on the wiring system at which current is taken to supply utilization equipment." No current IS or can be taken from a covered JB and it is not an outlet.
Mark
Old 02-05-2014, 07:01 AM   #9
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I have passed numerous inspections by covering the switched outlet required by the NEC with a blank plate.
The Following User Says Thank You to k_buz For This Useful Post:
Old 02-05-2014, 07:58 AM   #10
Rewards Points: 712
I've said many times that passing inspection does not mean that the installation meets the NEC requirements. A good example is that about 98% of the new homes I work in around here have all the EGCs in a box cut to about 3 inches long and twisted with the one left about 6 inches long and then placed in a steel ground crimp and mashed with side-cutters. This is two code violations; not enough free conductor at the box and connector not installed in accordance with the Listing instructions. However, this passes inspection every time. I'm currently trying to get inspectors to change this. It's a PIA when you have to rework those grounds for any reason.
Mark
Old 02-05-2014, 08:19 AM   #11
k_buz's Avatar
I don't think the intent of the NEC was to allow a switch in the basement to be the means to turn a second floor lighting outlet on/off, but that is legal as well.
"The intent of the code" is a bogus argument IMO. The code is very specific and if the intent was to require a fixture or receptacle, it would state just that.
Old 02-05-2014, 09:30 AM   #12
Rewards Points: 712
WADR, I wasn't arguing intent. The code is specific that an outlet is a point that current IS taken for utilization. "Is" is present tense and therefore the JB with cover IS NOT a point at which current is taken.
Just my opinion.
Mark
Old 02-05-2014, 11:11 AM   #13
Rewards Points: 266
It appears that the least expensive solution would be to put an single or duplex plug outlet in the ceiling.
The Following User Says Thank You to ionized For This Useful Post:
mpoulton (02-05-2014)
Old 02-05-2014, 12:19 PM   #14
Rewards Points: 712
I would just put a keyless porcelain fixture and call it done.
Mark
Old 02-05-2014, 12:40 PM   #15
k_buz's Avatar
WADR, I wasn't arguing intent. The code is specific that an outlet is a point that current IS taken for utilization. "Is" is present tense and therefore the JB with cover IS NOT a point at which current is taken. Just my opinion. Mark
If what you say is true, then by that definition, an unused duplex receptacle is not an outlet either.
busman (02-05-2014)
Disconnected Chandelier Eljaybee Electrical 5 06-29-2008 12:26 PM
