Removing Broken Light Bulb From Socket? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-08-2009, 07:43 AM   #16
Rewards Points: 156
A rubber stopper the correct size will work. My "light changing pole" that I got for my house came with several of them. (presumably for removing the bulbs you break when you're trying to install them with that darn pole!)
moondawg is offline   Reply With Quote
Old 01-08-2009, 09:40 AM   #17
I don't spray WD40 on the light bulb. I usually use the nozzle to place just o little toward the area on the side of the bulb where it threads into the socket after turning off the power. Then I use needle nose pliers. I have done this several times with no problems. I was just trying to help you. Safety is nothing to joke about so call the 800 line ( if WD40 has one) or read product safety information to double check before using WD40 near lightbulbs. Maybe I was just lucky that it worked very well for me.
Handyman Jim Noonan is offline   Reply With Quote
Old 01-08-2009, 10:01 AM   #18
Rewards Points: 2,350
I wasn't bustin' on you Jim. I thought you meant to leave a coating on the lamp socket so bulbs could be removed easily. Not saying it wouldn't work, just that I wouldn't trust it personally, that's all. I have used the antioxidant paste that is for aluminum service wires on flood light bulbs for this purpose. Not only is the product meant to be in intimate contact with electrical devices, it is non-flammable and keeps the lamp from stick to the socket, especially when the lamp base and socket are of different metal types.
Old 01-23-2009, 08:58 PM   #19
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
Originally Posted by CowboyAndy View Post
Im not sure how spraying wd 40 on a light bulb is going to stop my son from throwing something at it... maybe if i spray it in his eyes instead then he cant see to throw anyting at it!
I tried the needlenose pliars but no dice, there is only a small teenie tiny bit of metal showing. But I am going to try the other way suggested to open the needlenose on the inside and hold them open...
How did opening them up inside owrk out for you andy?
There is no such thing as a stupid question, but there is such a thing as an ignorant person, with a question, trying to learn.
Pudge565 is offline   Reply With Quote
Old 01-23-2009, 11:02 PM   #20
Rewards Points: 150
Send a message via AIM to Bocolo
You can also try a cork from a bottle of wine.
Bocolo is offline   Reply With Quote
Old 01-24-2009, 09:16 AM   #21
Whatamess
WD40 is great stuff for the moment but does not have lasting effects. It dries up in a few days. Things like 5-56 and others have an oil base that remains for a long time. Try this, use WD40 on a squeaky car door and in a few days it will be squeaking again.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 01-24-2009, 10:26 AM   #22
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
A new light fixture never fails to solve the problem.... and the lady of the house gets to go shopping..... It's a win win situation.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-24-2009, 11:12 AM   #23
WD = Water Displacement = not really a lubricant.
Old 01-24-2009, 11:47 AM   #24
UAW SKILLED TRADES
Stubbie's Avatar
I've also heard it makes for a good fish attractant.....spray your worm and bingo instant catfish at the end of your line.
Stubbie
Old 01-24-2009, 03:03 PM   #25
WD and sparks don't mix. HAve heard WD is good for arthritic joints though, mineral spiits or something to that effect.
Chemist1961 is offline   Reply With Quote
Thermostatically controlled light socket????? beebiz Electrical 28 11-26-2011 03:45 PM
Do they make light bulb converters that will still allow a light bulb? jimithing78 Electrical 15 11-28-2008 11:57 PM
Stupid question about energy efficient light fixtures farmerde Electrical 16 11-16-2008 09:26 PM
Light Socket Won't Hold Light Bulb colhollywood Electrical 3 08-16-2008 08:28 AM
Do I need training to change a light bulb? Mechelle Electrical 11 08-13-2008 07:26 AM
