Removing Broken Light Bulb From Socket? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-07-2009, 11:43 AM   #1
When is fishing season?
CowboyAndy's Avatar
removing broken light bulb from socket?
I know there is the old potatoe trick, but other than that what are the best methods of removing a broken bulb from a lamp holder (after killing the power first)?
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 01-07-2009, 11:49 AM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
I just grab onto the edge with some needle nose and turn. If it is a really hard socket to get it out of, I will crush in the sides of the bulb base, then use needle nose or linemans to rotate it out.
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 01-07-2009, 11:55 AM   #3
Tom Struble's Avatar
Rewards Points: 2,002
i once heard you can jamb a potato in there and turn make sure no power
Tom Struble is offline   Reply With Quote
Old 01-07-2009, 01:25 PM   #4
Needle nose and finesse.
220/221 is offline   Reply With Quote
Old 01-07-2009, 02:08 PM   #5
DIY Expert in Training!
If you can't get it with plyers you can cut a potatoe in 1/2 and use that.
gone_fishing is offline   Reply With Quote
Old 01-07-2009, 02:13 PM   #6
It's potato, dammit
Sincerely, Dan Quayle.
Old 01-07-2009, 02:13 PM   #7
Electrician
Originally Posted by 220/221 View Post
It's potato, dammit
chris75 is offline   Reply With Quote
Old 01-07-2009, 02:17 PM   #8
Old 01-07-2009, 05:52 PM   #9
joed's Avatar
Rewards Points: 13,308
If it is too tight for pliers then a potato is not going to work.
Old 01-07-2009, 06:15 PM   #10
Rewards Points: 2,350
Damn skippy! And if neither work, leave the potato in place and turn it on. The flames will loosen the shell.
Old 01-07-2009, 07:37 PM   #11
I've also found that if you grab the edge of the metal lamp plug with the needle nose pliers, you can tear the metal and actually peel the male plug from the female socket from the inside of the female socket, sort of like peeling an orange, in reverse.
The plug gives up after you peel back about 1/3 of the mating plug threads.
Old 01-07-2009, 10:25 PM   #12
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
A pair of needle nose pliers stuck in the base then opened. Keep force on them to keep them tight against the side while turning. My shop teacher showed us that trick.
There is no such thing as a stupid question, but there is such a thing as an ignorant person, with a question, trying to learn.
Pudge565 is offline   Reply With Quote
Old 01-08-2009, 12:34 AM   #13
A little WD 40 makes turning easier. It may also help prevent the new bulb from breaking the next time.
Handyman Jim Noonan is offline   Reply With Quote
Old 01-08-2009, 12:43 AM   #14
I don't know if using a flammable liquid in a lamp socket is a good idea or not. But, once you get the broken lamp out, a little antioxidant paste would be a better non-stick agent.
Old 01-08-2009, 07:11 AM   #15
CowboyAndy's Avatar
Im not sure how spraying wd 40 on a light bulb is going to stop my son from throwing something at it... maybe if i spray it in his eyes instead then he cant see to throw anyting at it!
I tried the needlenose pliars but no dice, there is only a small teenie tiny bit of metal showing. But I am going to try the other way suggested to open the needlenose on the inside and hold them open...
MY HOUSE OWNS ME!
Thermostatically controlled light socket????? beebiz Electrical 28 11-26-2011 03:45 PM
Do they make light bulb converters that will still allow a light bulb? jimithing78 Electrical 15 11-28-2008 11:57 PM
Stupid question about energy efficient light fixtures farmerde Electrical 16 11-16-2008 09:26 PM
Light Socket Won't Hold Light Bulb colhollywood Electrical 3 08-16-2008 08:28 AM
Do I need training to change a light bulb? Mechelle Electrical 11 08-13-2008 07:26 AM
