Removing Baseboard Heater In Bathroom - Electrical - DIY Chatroom Home Improvement Forum
Old 11-24-2011, 10:11 PM   #1
keeping things simple
Question
Removing baseboard heater in bathroom
I'd like to remove the small baseboard heater and thermostat in my bathroom. The heater is located behind the flush. I don't use it and it's all rusted etc.
To remove the heater I must install a flush mounted junction box to terminate the wires. I'm not sure about the thermostat. There are two other baseboard heaters on this one circuit so I don't think I can simply pull the wires out.
So I'm left with an ugly junction box in place of the ugly baseboard heater.
Is there any other way I can do this ?
Here's a pic of the heater.
I'm in the process of installing a new flush and flooring and thought I would take care of the heater in the process.
Hopefully there's another way. I guess I could leave it there and paint it
frankm1960 is offline   Reply With Quote
Old 11-25-2011, 06:24 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
Where is the t stat?
You should be able to remove the wire back to the t stat and put a blank cover there.
jbfan is online now   Reply With Quote
Old 11-25-2011, 06:25 AM   #3
Rewards Points: 1,216
When I redid my floor I unscrewed the baseboard from the wall and just left it loose until the floor was finished then just put it back down to the floor and re screwed it with new screws. I would do that unless your really dead set on removing it . Most wire have enough play to lift it a little, shut power off.
COLDIRON is offline   Reply With Quote
Old 11-25-2011, 10:33 AM   #4
The stat is in the top right corner in the pic.
If I removed the wire back to the stat wouldn't that leave me with a junction box on my wall in place of the stat?
As you can tell I don't do any electrical. I normally get an electrician but I thought I would look into doing this myself first.
Thanks for the responses.
Old 11-25-2011, 10:38 AM   #5
I can do that I think. I see some screws there but I'm thinking I would like to permanently remove it. I don't know if it's such a good spot for a baseboard heater and it's completely rusted out. Having it there makes it difficult to keep the area clean and it just collects dust which then collects moisture etc.
Maybe the key is to use it more to keep it from rusting.
In order to get it to look better I'm either going to have to replace it or sand it down and paint it.
Removing it permanently I'm still unsure about.
Thanks for your suggestion.
Register Heater in Bathroom Jeff40 HVAC 1 08-17-2011 03:49 PM
Install baseboard over/around existing trim of bathroom vanity? sunshine22 Remodeling 2 02-24-2011 08:39 AM
Electric Baseboard Heater Thermostats Edward1 Electrical 11 02-19-2011 09:04 AM
Electric Kick Heater for Bathroom meth HVAC 5 01-13-2009 09:31 AM
Electric Baseboard Heater Problem goombie Electrical 9 12-23-2008 12:13 AM
