Old 12-01-2010, 07:13 AM   #1
Removed ceiling lights - what to do with wires?
Hello,
I have a room in a relatively new house (1997) where I removed 2 out of the 4 ceiling lights. They are simple 48" T-3 fixtures wired through a knock-out in the top center of the light. The wiring is simply pulled through the sheetrock ceiling (through a hole about 3" in diameter). Due to the configuration of the room, this point on the ceiling is nearly at eye level (sloped ceiling).
I'm wondering what to do with the wires now that they aren't connected to the fixture. Obviously I've capped them off, but I can't imagine simply stuffing them back into the ceiling is code-compliant. Any thoughts?
Thanks,
- Brian
belias is offline   Reply With Quote
Old 12-01-2010, 07:30 AM   #2
Electrical Contractor
Install a round cutin box, put the wires inside and place a cover on the box.
Paint to match the ceiling.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 12-01-2010, 09:07 AM   #3
joed's Avatar
If you disconnect the wires at the other end so they are not powered, you could just push them up into the ceiling.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 12-01-2010, 10:27 AM   #4
Thanks for the quick replies!
jbfan: That's kind of what I thought but I was hoping to find some way around having to put a cover on the ceiling. Can I install a metal junction box higher up on the rafter, put a cover over it, and then patch the hole (i.e. cover is above the sheetrock in the ceiling space)?
joed: Good thought, but unfortunately it's wired in series and the wall switch still powers two other lights on the ceiling.
Thanks again
- Brian
Old 12-01-2010, 10:51 AM   #5
As long as you can get into the space above the ceiling without haveing to remove the ceiling.
Do you have access to the space above?
Old 12-01-2010, 10:53 AM   #6
Electrician
This sounds like the perfect spot for a smoke detector
VersaBar is offline   Reply With Quote
The Following User Says Thank You to VersaBar For This Useful Post:
Plumber26 (12-01-2010)
Old 12-01-2010, 10:55 AM   #7
No - but I'm going to have to cut out a decent sized plaster square to patch the rather large hole left behind the by the wires (which is right next to a rafter). So I figured I could use the square cut-out to mount a small box...maybe it's not going to be as easy as I think though...
Old 12-01-2010, 10:57 AM   #8
LOL - yeah...except counting the two hole I have to patch, that would be 3 smoke detectors in a 10' x 10' room....
Old 12-01-2010, 11:20 AM   #9
40+yrs Paint Trades
You can't seal the box up without access, against code.
hoz49 is offline   Reply With Quote
Old 12-01-2010, 12:41 PM   #10
RST
DIY Homeowner
Could you run a new wire between the two lights you are keeping, thus eliminating the need for a box?
I have a similar situation... attic space is tight (barely "accessible")... this is the solution I'm leaning towards for myself.
RST
RST is offline   Reply With Quote
Old 12-01-2010, 12:47 PM   #11
Originally Posted by belias
Hello,
Thanks,
- Brian
Tie neutral ground and load together, incase they are ever energized the breaker will trip. Dont want a stray line wire in the ceiling with voltage.
ianc435 is offline   Reply With Quote
Old 12-01-2010, 12:50 PM   #12
Electrician
Please read the thread before instructing someone to do something so dangerous. These wires will still be used for the lighting.
On another note, even if you were to abandon the wiring, what you propose is very dangerous. What if the breaker doesn't trip (which is definitely known to happen)? What if the homeowner just energized a dead short in their attic? That makes for a nice heating element waiting to burn their house down. I would MUCH rather have a capped off "stray line in the ceiling with voltage".
Jim Port (12-01-2010)
Old 12-01-2010, 01:49 PM   #13
40+yrs Paint Trades
"Home cookin"
Old 12-01-2010, 02:54 PM   #14
They make access panels that pop into place in ceilings and walls.
This will be the only way you can put the box into the ceiling.
Old 12-01-2010, 03:59 PM   #15
If you abandon wires absoluteley cap off all wires (hot,neutral,ground) into one nut on both sides.
This way if these wires are ever energized the fuse will blow.
If they are left live, you need a box(left accesable).
You got two choices. One's better cosmetically, but could be more work.
michaelcherr is offline   Reply With Quote
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
wiring problem: 120V to 12V Halogen Ceiling Lights with transformer Uncledan Electrical 3 01-20-2010 06:32 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
ceiling fan installation PLEASE someone help finleygoddess7 Electrical 35 03-08-2008 10:41 PM
halogen lights fitted into a polystyrene ceiling - safe? jono_wales Electrical 1 03-07-2005 03:52 PM
