Remove Switch From Controlling Outlet/wire Wall Light To Wall Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 08-26-2010, 01:42 PM   #1
Rewards Points: 14
Remove Switch from controlling outlet/wire wall light to wall switch
Hello, I have a light switch in my room that currently controls 1 outlet. I would like to have power ran from that outlet up the wall (about 4 feet) so that I can install a wall mounted light and have the light switch control just the new wall light and not the outlet. I have been looking for details on how to do this, I have replaced light switches/Outlets and installed light fixtures on exisiting wiring before just never anything like this... thanks!!!
salesbyashley is offline   Reply With Quote
Old 08-26-2010, 01:54 PM   #2
Licensed electrician
Rewards Points: 1,266
Can you describe the number and colors of wires in the switch box and attached to the switch?
Old 08-26-2010, 03:07 PM   #3
joed's Avatar
Rewards Points: 12,002
There area several way this could be wired. How it is wired will determine if it can be and how.
This link should help.
Convert switched plug to to switch light fixture
What wall switch for bath fan/light/heater? janralix HVAC 8 07-20-2009 05:07 PM
What wall switch for bath fan/light/heater? janralix Electrical 6 07-20-2009 12:14 PM
Remove light switch broadbear Electrical 2 03-29-2009 02:39 PM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 02:23 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
