Remove A Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 08-08-2012, 10:26 AM   #1
Remove a switch
How do I remove a switch that currently controls an outlet ? Please see photo.
The switch I want to remove is A. It controls power to an outlet. Switch B controls an exterior light. Both switches are on the same circuit. The objective is to remove switch A so power always goes to the outlet and leave switch B intact. Seems like there are 3 cables entering the box.
timcsi is offline   Reply With Quote
Old 08-08-2012, 10:34 AM   #2
Licensed electrician
Rewards Points: 1,020
The electrical code requires a switch controlled receptacle or lighting outlet in many rooms. Removing the switch may create a code violation. What room is this in?
k_buz (08-08-2012)
Old 08-08-2012, 11:39 AM   #3
it's actually in the living room
Old 08-08-2012, 12:10 PM   #4
That would be one of the rooms that would require the switched receptacle or a switched lighting outlet.
Old 08-08-2012, 05:03 PM   #5
"So I Re-Wired It"
MisterZ's Avatar
is it a half-switched outlet?? these rooms only require half-switched oulets.
if the whole duplex is switched, you can remedy this by removing the break-off tabs betweent the terminals.
of course you'll need to supply power for the unswitched portion (which should be the top)
BTW, nice pics. all wires are clearly identifiable.
however, i will not comment on the wire job or switches
Knowledge is Power, but 240v can Keel You!!
MisterZ is offline   Reply With Quote
Old 08-08-2012, 08:27 PM   #6
Above answers are correct that code requires a switched lighting outlet and that is probably what that switch that you want to remove is for.
Code issues aside and you really want to do this, follow below.
Turn off power!
Instructions assume Power is coming in on wire 6. If not sure test.
Remove wire 3 from switch A.
Remove wire 1 and 2 from switch A
Remove wire 4 and 6 from switch B
Discard wire 4 and 1
Splice wire 2,3,6 together along with a tail piece of wire.
Terminate your new tail piece to the same location on switch B that wires 4 and 6 came from.
Put Switch B back in box where it came from.
You can put Switch A back in the box if you want even though it does not do anything anymore or you can go buy a switch plate that has a single switch opening on one side and a blank on the other.
Turn power back on and your done.
parman is offline   Reply With Quote
Old 08-08-2012, 08:56 PM   #7
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Since an answer was given on how to do this (and I do agree that you shouldn't due to the code violation).....
Take the red wire off the switch and tie it into the black wirenut....done.
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Remove light switch broadbear Electrical 2 03-29-2009 02:39 PM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 02:11 AM
