Old 11-27-2009, 12:55 PM   #1
Remove old light fixture (hanging)
I am trying to replace an outdated hanging light fixture to a normal flush mount fixture. I've replaced several fixtures and know how to do it once removing the old one. However, I cannot remove this old fixture. The base will not spin loose and I see no other way to remove the fixture. It's an old house and this fixture could be several decades old. Is there some trick to remove the base and fixture for old hanging lights? I can send a picture if anyone requests it. Thanks.
dj928 is offline   Reply With Quote
Old 11-27-2009, 02:13 PM   #2
joed's Avatar
Post a pic. The cowl either unscrews or snaps off or has a nut holding it.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 11-27-2009, 03:40 PM   #3
"Error on page" every time I press the attachment link button...
Old 11-28-2009, 11:37 AM   #4
joed's Avatar
Attachment button works fine for me. Another box opens and asks where the pic is located.
Old 11-28-2009, 01:14 PM   #5
It doesn't work for me. Can you PM me or let me know how to PM you so I can send it via normal email? Thanks.
Old 11-28-2009, 03:18 PM   #6
Just call me Andrew
Try IE if you are using firefox.
Or, post it to http://www.imageshack.us and then link to it here.
secutanudu is offline   Reply With Quote
Old 11-29-2009, 10:47 AM   #7
Firefox worked.
Old 11-29-2009, 11:43 AM   #8
joed's Avatar
Center where the chain is attached and the wire comes out should unscrew letting the entire fixture and cowling down.
Old 11-30-2009, 03:06 PM   #9
OK I tried that before and it wouldn't budge. I didn't want to force it. But if that's where it is, I'll get pliers and try again. Thanks.
Old 12-02-2009, 12:42 PM   #10
OK it took a wrench and torque to get the center screw off but the cowling (part flush to the ceiling) still won't budge. Before I start chipping away at the ceiling around it, please confirm that you don't think there's anything else holding it in place up there. Thanks.
Installing One Light Fixture Causes Another Not To Work pythagras Electrical 2 07-02-2009 09:15 PM
Help! wall light fixture w/ switch 8christiest Electrical 3 08-28-2007 04:21 PM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 07:22 AM
converting hanging light fixture to plug dukeswalker Electrical 2 09-18-2006 10:03 PM
find switch to control outdoor light fixture CaymanAg Electrical 1 07-10-2005 09:43 PM
