Remove Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 03-28-2009, 07:20 PM   #1
Remove light switch
I am refinishing some drywall, and I want to remove a light switch that I no longer need. Can I just unscrew the wires from the light switch and patch it up? Is there any issue with breaking the circuit (will I lose all power on that wall?)? Should I protect the exposed wiring somehow before patching?
Thanks!
broadbear is offline   Reply With Quote
Old 03-28-2009, 08:11 PM   #2
as seen on tv
Rewards Points: 150
You should disconnect the switch to see if anything else is fed from it. Then trace wiring and disconnect feeder for switch remove wiring/ box, patch away!
qbert is offline   Reply With Quote
Old 03-29-2009, 01:39 PM   #3
If there are more than 2 wires in it (one cable) do NOT patch over it.
I will hunt you down and kick your ass
Only two wires, cap them, put a blank cover on the box and patch away.
A simple blank cover is always the best approach. Someday, someone may want to unremodel your remodel.
220/221 is offline   Reply With Quote
A simple 2 light --1 switch question? redondo11@msn.com Electrical 7 11-05-2008 08:35 AM
Problem changing light switch grgryl Electrical 14 08-10-2008 01:26 PM
GFCI light switch trips once per night ???? mw6263 Electrical 11 07-25-2008 11:05 AM
New light switch burns out dsbutler71 Electrical 12 09-05-2007 07:34 PM
