-   -   Remove light switch (http://www.diychatroom.com/f18/remove-light-switch-41297/)
broadbear 03-28-2009 07:20 PM
Remove light switch
I am refinishing some drywall, and I want to remove a light switch that I no longer need. Can I just unscrew the wires from the light switch and patch it up? Is there any issue with breaking the circuit (will I lose all power on that wall?)? Should I protect the exposed wiring somehow before patching?
Thanks!
qbert 03-28-2009 08:11 PM
You should disconnect the switch to see if anything else is fed from it. Then trace wiring and disconnect feeder for switch remove wiring/ box, patch away!
220/221 03-29-2009 01:39 PM
If there are more than 2 wires in it (one cable) do NOT patch over it.
I will hunt you down and kick your ass :furious:
Only two wires, cap them, put a blank cover on the box and patch away.
A simple blank cover is always the best approach. Someday, someone may want to unremodel your remodel.
