Remote Switch Or Dimmer??? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-09-2013, 12:13 AM   #1
Remote switch or dimmer???
I am having a box installed in the ceiling to power a chandelier. Problem is, the ceilings are 19' and there is not way to get a switch to the area that we would like for it to be, beside the other switches for the great room. Well, I guess there is a way that would involve a lot of drywall repair, but I am not going to do that.
I have two choices: 1. Tie into the existing light that shines towards the mantle to highlight a painting and run the switch for BOTH the new chandelier AND the existing art light. Or, 2. Utilize a remote switch ( I didnt know that existed). How reliable are these remote switches? Will I be stuck in the near future with an inoperable switch, thereby not having control of my chandelier? Or should I just run both lights on the same dimmer?
Thanks in advance for the input.
Rich
vtl382 is offline   Reply With Quote
Old 03-09-2013, 12:36 AM   #2
Retired from the grind
Rewards Points: 6,652
You would need separate runs of romex to each light, back to the box that all of the switches are in, so that you can either install a control pad that allows dimming via the pad, or a app on your android phone/tablet, or iphone/ipad. This is one option http://www.smarthome.com/2477D/Switc...d-White/p.aspx There are more in the smarthome.com site that you can go and search through.
Old 03-09-2013, 08:35 AM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Lutron Pico Switches....
http://www.homedepot.com/p/t/2023260...a#.UTtIu6V8v0c
Replace bathroom light switch with dimmer switch ToddD Electrical 11 05-06-2012 05:58 PM
Replacing a dimmer switch with a regular switch for a ceiling fan RP DeMars Electrical 0 04-18-2012 03:25 PM
Dimmer switch wiring question joez148 Electrical 2 07-15-2010 10:49 AM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
