Remote Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-05-2008, 11:10 PM   #1
Remote Switch?
This may sound like a silly question, but is there such thing as a remote switch?
Here is the scenario. I have a 2-story family room, and I would like to install a ceiling fan to help with air circulation. I have access to wiring for the recessed ceiling lighting, so I can use that to power the fan. However, I am trying to figure out any easy way to wire a switch down to the lower level.
Now, if there was such a thing as a remote switch, that would be wonderful! But my guess is there is no such item. So, does anyone have any suggestions for me without doing too much damage to the existing sheet rock? TIA
jasoncw is offline   Reply With Quote
Old 10-05-2008, 11:39 PM   #2
Rewards Points: 2,350
You mean like this: www.ecogeek.org/content/view/2170/77/
Us electricians aren't supposed to tell you lay folks about this stuff, 'cause it makes it easier to do the stuff yourself. Then, you won't call us! But I'll let you in just this once.
Old 10-06-2008, 12:05 AM   #3
Very nice! Any idea how much the individual switches are going to run? I was looking on Verve's site (Masco is just down the street from me), and it says you can call for individual switches. I just don't want to have phone sticker shock. lol
Old 10-06-2008, 12:09 AM   #4
I saw one model that was $149. But once you buy wire, call an electrician, and fix and paint any sheetrock that may need to be cut, well, $149 really isn't that bad...
Old 10-06-2008, 12:11 AM   #5
Yowza. Good point, though. Something to think about.
So no other "clean" ways to wire a switch to the lower level? I didn't think so, but thought it was worth a shot.
Old 10-06-2008, 12:32 AM   #6
It depends on how your house is laid out. If you have a wall that lines up from the top floor to the floor you want to get to, then you can purchase a long flex bit and extension and drill from the attic down to the first floor. Or you may find that you have a chase for plumbing or HVAC ducts that runs between floors that you might get a wire through from the attic or basement.
Sometimes, you can find a closet that is in the right spot and cut the sheetrock out of the back or side to allow you access to the floor above or below. There are ways, believe you me. I have never met a wall I couldn't fish.
Old 10-06-2008, 07:04 AM   #7
Licensed electrician
Rewards Points: 1,608
If you could install a switch nearby you might want to look at this.
http://www.lutron.com/CMS400/default.aspx?app=Maestro
Old 10-06-2008, 08:02 AM   #8
x10...
http://www.smarthome.com
Billy_Bob is offline   Reply With Quote
Old 10-06-2008, 09:52 AM   #9
I use X10. My whole house is X10 and I can control any light, any fan, the furnace, the water supply from anywhere in the house or anywhere in the world.
Get one of these http://www.smarthome.com/2476S/INSTE...-White/p.aspxa and install it as the fan switch.
Then get one of these http://www.x10.com/automation/x10_tm751.htm and plug it into the wall.
Then get one of these http://www.x10.com/products/x10_hr12a.htm and you are good to go.
X10 is having a sale on some of this stuff. Here is the list I just got form one of my home automation friends.
1 - ActiveEye motion sensor
3 - Lamp modules
1 - Slimline wall switch (stick-a-switch)
1 - 15 amp appliance module
1 - TM-751 wireless transceiver
1 - CM11 powerline interface
for $29.95
Everything you need is in this kit except the wall switch. The transceiver, the remote wall switch, and you get 3 lamp modules that can control them remotely also. It is cheaper than buying the stuff separatly. You can either keep the rest of the stuff or sell it or toss it....
If you decide to go for this please go to shed.com and use the X10 click through at the top of the page. He gets a kick back for anyone buying X10 stuff going through his site and it helps him pay the bills for keeping his site up. It is a home automation site for Mac users.
I have been using X10 for over 20 years and love it.
Anyhow this is one idea and is way less hassle than wiring a remote switch. This system can also grow to include more stuff.
At my vacation home I shut off everything including the will pump and the hot water heater. When I walk in there I push one button and it turns off the security systems, turns on the well pump, the heat water heater and a few other things. The well pump is in another building about 400 feet away and it is so nice to not have to walk over there to turn in on.
Marvin Gardens is offline   Reply With Quote
Old 10-06-2008, 06:57 PM   #10
Thanks for all the help, guys. On the way home from work I stopped by Lowe's and saw this:
http://www.lowes.com/lowes/lkn?actio...esc&lpage=none
But I think I'm going to go with that X10, it looks like a lot more fun.
Old 10-06-2008, 06:59 PM   #11
And BTW, InPhase277, I called Masco, and the Verve (EnOcean) is not yet sold retail, so that is not an option.
Old 10-06-2008, 09:44 PM   #12
The EnOcean model is just one of several. But no matter. Good luck. I like the concept only because the remote switch never needs batteries.
3-Way Switch Wiring MrBill_DIY Electrical 8 09-07-2008 05:53 PM
need to find wall switch remote..does that exist? tarheelblue Electrical 7 09-05-2008 05:51 AM
Hampton Bay Remote Ceiling Fan esqjd Electrical 16 01-14-2008 05:32 AM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
