Remote Pump Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 05-12-2009, 06:09 PM   #1
Rewards Points: 14
Remote pump switch
I am trying to find a remote switch to operate my waterfall pumps.
Right now the two pumps are controlled by a standard wall toggle switch mounted in a weather proof box located in the yard. I would like to be able to remotely operate that switch from inside the house.
I have searched everywhere I can think of, and the ones I am finding are for incandescence bulbs only, 300 watts maximum. My pumps are just under 4 amps, each.
I can find remotes that operate a unit that plugs into an outlet, them the pump plugs into the unit. I want something that will operate the switch.
Even a remotely operated relay would do the job, if I could find such a thing. I know it's out there, just can't find it.
Anyone have a suggestion..? There must be more people than me that like to operate pumps remotely....?
Donn2390 is offline   Reply With Quote
Old 05-12-2009, 07:51 PM   #2
Using an incandescent remote to operate a relay will likely be the most economical way of doing this.
Hmmm! Now you've given me food for thought, for my pond!
Old 05-12-2009, 08:00 PM   #3
Use any relay with contacts that can handle a 4A inductive (motor) load with, let's say, a 24vac coil. Then you run low voltage from a bell 'former out to the relay, which replaces the wall switch. I don't know what the NEC has to say about this, though.
www.hosfelt.com, p/n 45-640 will handle it. $1.75 plus shipping.
Other places that may have a suitable part are Allelectronics, Digi-key, Mouser, Grainger and Jameco.
Vertical float switch for a flotec sump pump Kimp Plumbing 2 02-24-2009 10:17 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Remote Switch? jasoncw Electrical 11 10-06-2008 09:44 PM
need to find wall switch remote..does that exist? tarheelblue Electrical 7 09-05-2008 05:51 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
