Remote Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 07-15-2013, 04:27 PM   #1
remote lighting
i have 2 scounces on one circuit and 2 on another circuit ..with no switch .. they have pull chains..looking for a remote sort of like a remote fan control to control these lights.. can anyone recommend something.. i would use a fan remote but the module that gets mounted behind the fixture is a little big
timbre is offline   Reply With Quote
Old 07-15-2013, 04:30 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
You could cut in Lutron Maestro wireless switches below the fixture, then add a Pico to control both fixtures.
Old 07-16-2013, 06:12 AM   #3
My home automation is mostly a product of Smarthome, so I am mostly familiar with their products. They have a smart light bulb called bulblinc:
http://www.smarthome.com/2672-222/IN...ED-Bulb/p.aspx
If that style of bulb fits in your fixtures, you could then control it from something like:
http://www.smarthome.com/2342-232/IN...4-Scene/p.aspx
While I have not used one, the Phillips "Hue" seems also to be gathering some media coverage. That bulb appears to be designed to allow one to control a bulb from a smartphone or certain harmony remote controls. You may want to check that out.
oberkc is offline   Reply With Quote
LED Cabinet Lighting - Wire Ga. - Run Lengths - 12v or 24v driver - So many ??? roundbox52 Electrical 1 11-08-2012 08:06 AM
Can I cannabalize the remote set on a Hunter fan? mike720 Electrical 3 10-07-2012 10:14 AM
Kitchen Remodel LED Lighting Problems jimklug Electrical 2 07-02-2012 01:35 PM
Wiring a ceiling fan with remote and dual switches Scotter86 Electrical 0 07-12-2011 09:19 PM
Ceiling fan remote issues Richo Electrical 7 06-06-2011 09:09 PM
