Remote Controlled Light Switch - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-26-2013, 01:14 AM   #16
Remote Controlled Sockets
I use plugged in lamps and control them through these remote control sockets, you can switch 3 or 4 independantly
Mr Kite is offline   Reply With Quote
Old 04-08-2013, 05:24 PM   #17
Lightbulb
Use home automation products
Wouldn't it be easiest to just simply replace the switch with a remote controlled one?
There are dozens of them that would work, we use them every day in home automation. Consider the type of lighting you are using first, identify if a neutral is in the same box, then just replace the existing switch with an HA switch using any of the following technologies (X-10, Insteon, Zwave, or UPB, infrared even, plus there are wireless proprietary ones as well).
I can post some recommendations for different products if this is not a dead thread, but in a nutshell there is not much to it after you answer the aforementioned questions, make your choice based on those and wire it in.
Then choose a remote in the same technology or get one that can send receive infrared and use a universal remote or even an android/iphone. You could even use a PC or laptop to BE the remote and control it from your PC or over the internet anywhere in the world.
Just some suggestions!
haworld
haworld is offline   Reply With Quote
Light in one lighted three-way switch not working dalepres Electrical 2 06-26-2012 06:27 AM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Bedrooms have no ceiling light, light switch controls one electrical outlet? notenoughtime Electrical 16 05-25-2009 12:09 AM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 10:51 PM
