Remote Control For Pump Operation - Electrical - DIY Chatroom Home Improvement Forum
Old 01-26-2012, 05:46 AM   #1
Remote control for pump operation
Hi,
I'm trying to install a remote control switch for my water pump (1HP 220V). I have an electronic remote control switch and transmitter which i installed initially directly to the pump but shuts off after a few minutes. My hypothesis is because it cant carry the load. I was thinking of intalling a relay between the controller and the pump. Is this the right approach and if so what kind of relay and rating should i use. Can also pls throw in a wiriing diagram for the relay.
Many thanks,
Donnie
donnie v is offline   Reply With Quote
Old 01-26-2012, 05:57 AM   #2
Julius793's Avatar
Originally Posted by donnie v
Hi,
Many thanks,
Donnie
Can you give us locations of where you want everything?
the transmitter powering a relay sounds fine. Go to your local electric supply they should have a universal one that can work.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-26-2012, 07:44 PM   #3
Hi, thanks for the reply. i plan to put the receiver and the relay in the pump house which is located at the ground floor while i will be transmitting from the 2nd floor.
remote control for aircompressor rick taylor Electrical 19 12-01-2010 10:42 PM
Remote Control Ceiling Fan - switch required? bvbellomo Electrical 7 11-10-2010 08:07 AM
Switch/outlet - remote control devices? ccjr019 Electrical 2 12-16-2009 08:58 AM
AprilAire - Humidity Control Remote Mounting AndrewF HVAC 12 02-20-2009 10:35 AM
dual Remote control deck hand Home Theater 5 01-31-2009 04:53 PM
