Remote Control For Aircompressor - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-01-2010, 04:25 PM   #16
WDR
remote
search dust collector remote on the internet and you should be able to fined what you need, I think I have seen one rated at 15 amps or more, a lot of different places sell them.
WDR is offline   Reply With Quote
The Following User Says Thank You to WDR For This Useful Post:
rick taylor (12-01-2010)
Old 12-01-2010, 06:39 PM   #17
wdr i just took a look those dust collector remotes. Ithink were starting to dig in the right hole. My aircompressor says 115/230 the dust collector remotes 110 vac. Will the 110vac still work or will it some how under power my compressor motor.
rick taylor is offline   Reply With Quote
Old 12-01-2010, 09:28 PM   #18
WDR
compressor
If the compressor says 115/230 it should also have two amp draw ratings the lower one would be for 230 and the higher for 115. The reason it would have two ratings is most motors can be wired for multiple voltages. If your compressor is wired for 115 and the amp draw is les then what the remote is rated for it will work just fine. If the compressor is wired for 230 then you will need to rewire it for 115 or get a 230 volt remote (I believe I have seen them before) and use that, however you would have to have a 230 volt power source.
Old 12-01-2010, 10:10 PM   #19
Compressor is running standard 115vac. Amazon has 3or4 dust collector remote switches 110vac.that powers up to a 1.5hp motor, built in 20 amp reset breaker.How many amps do you think a 1.5 dust collector motor draws at start up compaired to a 1.5hp aircompressor?
Old 12-01-2010, 10:42 PM   #20
WDR
start load
I think the remote would work fine with the air compressor, a dust collector needs a fairly powerful motor. I can not guarantee it would work but aside from building something your self I think it is the best option.
Remote Control Ceiling Fan - switch required? bvbellomo Electrical 7 11-10-2010 08:07 AM
Switch/outlet - remote control devices? ccjr019 Electrical 2 12-16-2009 08:58 AM
AprilAire - Humidity Control Remote Mounting AndrewF HVAC 12 02-20-2009 10:35 AM
dual Remote control deck hand Home Theater 5 01-31-2009 04:53 PM
Silly problem with TV remote control proofer Home Theater 8 09-24-2008 07:27 AM
