Old 02-11-2007, 08:33 AM   #1
Remodeling upper...existing runs to the basement?
I am remodeling the upper level of my home and was curious to know what people do with existing runs to the basement from the attic area. My basement is competely finished. If I'm taking walls down and moving them on the upper level, what do you do with existing runs travelling down walls that will be moved? The existing wiring is run through conduit...1967 vintage. Will I need to replace all that wiring and runs from the panel and fish to the basement?
wease is offline   Reply With Quote
Old 02-11-2007, 08:51 AM   #2
Are any of the walls that you are moving load bearing walls?
redline is offline   Reply With Quote
Old 02-11-2007, 09:15 AM   #3
Some are load bearing. Most are not.
Old 02-11-2007, 11:49 AM   #4
joed's Avatar
The unused wires in the conduit can be just pulled out. Pull in a string so you can pull new wires in when needed.
There is no need to replace any wires that can be used again if they are the the correct guage and length.
Remodeling my basement diyer4162 Remodeling 4 08-09-2007 10:19 AM
Basement bathroom remodeling amakarevic Building & Construction 2 04-12-2007 08:59 PM
Refinishing Or Remodeling My Basement Rifeman Building & Construction 4 03-12-2007 11:13 PM
Basement Remodeling Help DMonkey6972 General Discussion 5 01-15-2007 01:35 PM
Remodeling basement for 1st time!?!?! BCane14 Remodeling 7 03-18-2005 10:07 AM
