Remodeling - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2011, 09:41 PM   #1
remodeling
can I just get architect to put all my ideas on paper and then go to town to get permits and do all by my self? I'm located at Mahwah, NJ
thanks,
DarekAP is offline   Reply With Quote
Old 01-08-2011, 09:47 PM   #2
Licensed electrician
Rewards Points: 1,874
Some areas require a licensed contractor to pull the permit. Call your building officials.
Old 01-08-2011, 10:02 PM   #3
What ideas ?
I've done most of my own plans
Old 01-08-2011, 10:26 PM   #4
remodeling
I think to remodeling entire house, and finish basement ( plus rise up ceiling at list 2' on one level ) It's split level house.
Old 01-09-2011, 07:38 AM   #5
DIY staff
Rewards Points: 7,174
An architect can design and make your drawings--Bring lots of photos and make a drawing of your house with measurements so he or she will understand what you are hoping to do.
Your local building department will tell you what you can do and what you need to hire out.
Some areas do not allow a homeowner to do electrical or plumbing--Mike--
Old 01-09-2011, 11:42 AM   #6
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
Here in California I know that you can hire an Architect to do drawings for you, go to the Planning and Building Departments and pull your own permits and do the work yourself.
Depending on the size and scope of the project you may need an engineer involved too. You can also use a designer to do the same thing, that is what I do for people.
As long as you do the work as shown on an approved set of plans yes, you can do all that.
Andy.
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
oh'mike (01-09-2011)
remodeling basement.....question on building ledge bigbrad123 Building & Construction 2 10-20-2010 11:35 AM
Remodeling a converted carport scarymary Introductions 2 04-18-2010 07:14 AM
Remodeling during winter - safety? Snav General DIY Discussions 8 02-17-2010 06:58 PM
Remodeling Kitchen/Bath - Where to Begin??? msmiller36 Roofing/Siding 1 01-06-2010 03:44 PM
