Remodel Style Recessed Light Code Question - Electrical - DIY Chatroom Home Improvement Forum
Old 05-22-2008, 06:00 PM   #1
Remodel style recessed light code question
Hi all, I am in the latter stages of a major basement remodel.
I was planning on installing a pair of 4" "remodel" can lights in hallway. These are the kind that you insert through a hole and clamp directly to the drywall. I wired it as a basic 3-way switch with the two fixtures in the middle.
The problem is the metal arm and the little tiny metal junction box on the fixture. Too many wires to fit in the box and the arm/box is also getting in the way preventing a flush fit.
1) Can I (legally) just remove the arm/box from the rest of the light?
2) Can (or should) I add a regular plastic box inside the joist? It would be buried, but I still have access to it though the light fixture since I can just push up the calmps and take it out.
3) The factory box on the fixture has a ground wire, but I could also just screw a ground wire to the "shell" of the lamp housing.
I have followed all codes to this point, but my first concern is always safety. I'd like to stay with the recessed lights because it is a basement hallway with slightly lower ceiling and I have soffits on each side of the lights.
Thanks.
bjstewa is offline   Reply With Quote
Old 05-22-2008, 06:17 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
First I must ask, how many wires could you possibly have to put in these boxes???
DO NOT! remove the arm from the fixture!
DO NOT screw a ground wire to the can.
If you HAD to you could put a J-box in the ceiling IF it fits through the hole of the fixture, but this is an absolute last resort.
Old 05-22-2008, 08:00 PM   #3
The j-box on the light is 2.5 x 3.25 x 1.5" or roughly 12 cu. in.
For the 3-way switched connection I have (2) 2-wire and (1) 3-wire romex coming into each fixture.
The metal panels on the j-box on the light says "2 in and 2 out". I wasn't sure if that meant the individual wires and if it included the black and white going directly to the bulb housing.
Basically - I don't think I can cram 10 wires (plus the two for the fixture) into the box.
What is the purpose of the little arm? It doesn't actually attach to anything. It just seems to hold the box.
Here's a scan of what I'm wanting to install.
Old 05-22-2008, 08:24 PM   #4
Licensed Pro
Run the 3 conductor between the switches and just the two conductor from one switch to light to light.
Old 05-22-2008, 08:34 PM   #5
Why do you have three wire in the cans. Why don't you run your travelers straight from one switch to the other
bwinters12 is offline   Reply With Quote
Old 05-22-2008, 08:34 PM   #6
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
to much wire for that box
that's because it is not big enough legally for that many wires
that is like asking what the wall of yoru house is for as all I see it doing is connecting the roof to the floor. That arm is an integral part of the fixture and removing it would defeat the UL listing i.e. illegal.
Old 05-22-2008, 08:35 PM   #7
I agree with HH.
HOW are you making this work???? What wires are going where?
Old 05-22-2008, 09:01 PM   #8
It's kind of a long story as to why things are the way they are, but it is mostly related to what was already in place when the house was built.
Here is the exact circuit config. This is from Black and Decker complete home wiring.
Old 05-22-2008, 09:25 PM   #9
WOW!
Recessed Lighting vs Electrical/Mechanical/Fire Code 909 Electrical 3 05-21-2008 01:11 PM
Adding one recessed light to exsisting switch... JayBird Electrical 1 04-03-2008 07:32 PM
can light question trptman Electrical 13 04-19-2007 05:11 PM
Recessed light plan foiled? kcrossley2 Electrical 8 03-14-2007 11:08 PM
recessed light farrington135 Electrical 3 12-03-2006 12:02 PM
