Remodel Recessed Lights - Insulation Contact Vs Non-insulation Contact - Electrical - DIY Chatroom Home Improvement Forum
Old 11-26-2010, 04:10 PM   #1
Remodel recessed lights - Insulation contact vs non-insulation contact
I am putting in some recessed lights in a ceiling that does not have insulation. Now, a guy in the electrical section at Home Depot told me that it would be ok to put in the insulation contact lights (remodel type) even though there won't be any insulation around them. Is that accurate? He did say, however, that you can't do the opposite, which would be to put a non-insulation light in a space where it will have insulation touching the can.
He said something about the non-insulation lights having a built-in thing that makes them cut off if they get too hot, and that you wouldn't have that problem with the insulation contact.
No offense to any of you that work at HD, bug I just wanted to get some other opinions on this subject since it's hard to tell who knows their stuff at those stores.
Thanks!
Swaff
swaff is offline   Reply With Quote
Old 11-26-2010, 04:28 PM   #2
Master Electrician
Rewards Points: 3,678
IC cans may be used for either application. IC cans have thermal cut outs.
brric is online now   Reply With Quote
How Many Recessed Lights SHould I use? jonathan03 Electrical 0 03-15-2010 12:03 AM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 09:14 PM
Can I Mount Can (recessed) Lights Vertical? jmaguire123 Electrical 9 11-28-2006 08:49 AM
power source for recessed lights Jackman Electrical 1 09-18-2006 08:30 PM
Do I have a Fire Hazard with New Recessed Lights - Help! Christy Electrical 8 05-08-2006 08:31 PM
