Remodel Recessed Housing Proximity To Stud - Electrical - DIY Chatroom Home Improvement Forum
Old 01-02-2010, 02:31 AM   #1
Rewards Points: 278
remodel recessed housing proximity to stud
The clip on the remodel housing such as H99RT.. how close can I install it to the ceiling stud?
I took out a previously nailed in ceiling box and there is a hole in the ceiling, I wanted to put a 4" unit there. However I got the new construction housing and found out no matter what it cannot be positioned that close to the stud.
I am hoping the remodel housing would work. Since the clips are spread out 4 ways. I will also cut the new 4" circle a little further out if I can.
DIYGST is offline   Reply With Quote
Old 01-02-2010, 02:54 AM   #2
I have no Ideal, I just didn't want you to feel like no one is awake out here but you, best wishes with you ceiling. If you don't have certain codes where you live could you place it where you want a patch the hole that's left?
SolarChick is offline   Reply With Quote
Old 01-02-2010, 03:00 AM   #3
Rewards Points: 278
Thanks.. the hole is where I want my recessed accent light actually, my ceiling has popcorn so for now I will not be able to match the repair nicely if I relocate it. So definitely want to use the existing hole enlarge to 4" and go for this.
Old 01-02-2010, 03:03 AM   #4
Popcorn comes in a spray can a Shrewin-Williams paint supply store.
Old 01-02-2010, 03:05 AM   #5
Rewards Points: 278
Well I am not going to use for this project.. Curious have you used it? does it match well?
Old 01-02-2010, 03:40 AM   #6
Yes, as an apartment manager the maint had to use it, it can be messy though and takes practice.
Remodel Recessed Light Questions Tom5151 Electrical 16 12-16-2009 01:48 AM
remodel recessed lighting DIYGST Electrical 9 03-02-2009 01:47 PM
Remodel style recessed light code question bjstewa Electrical 8 05-22-2008 09:25 PM
IC vs. IP recessed housing sastexan Electrical 6 02-26-2008 09:15 PM
