remodel recessed housing proximity to stud
3K views 5 replies 2 participants last post by  SolarChick
The clip on the remodel housing such as H99RT.. how close can I install it to the ceiling stud?
I took out a previously nailed in ceiling box and there is a hole in the ceiling, I wanted to put a 4" unit there. However I got the new construction housing and found out no matter what it cannot be positioned that close to the stud.
I am hoping the remodel housing would work. Since the clips are spread out 4 ways. I will also cut the new 4" circle a little further out if I can.
Thanks.. the hole is where I want my recessed accent light actually, my ceiling has popcorn so for now I will not be able to match the repair nicely if I relocate it. So definitely want to use the existing hole enlarge to 4" and go for this.
