Remodel Recessed Fixtures For Thick Ceilings - Electrical - DIY Chatroom Home Improvement Forum
Old 06-10-2012, 10:51 PM   #1
Power Gen/RS Engineer
Rewards Points: 566
Remodel recessed fixtures for thick ceilings
Hey y'all!
I want to install several 4-inch remodel can lights in my kitchen. The ceiling construction is 1/2 inch drywall over lath and plaster. I installed remodel cans in another part of the house with similar ceiling construction and getting the clips in was hell! I was under the impression that there was a manufacturer that produced cans with a screw-clamp that worked better with thicker and/or irregular ceilings.
Any help?!
Thanks!
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 06-11-2012, 07:20 AM   #2
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
I've run into that before and you're right, it's a pain. The remodeling cans locally available at the supply houses were all designed for 1/2" - 5/8" drywall. We're in the same area. I'd call Evergreen Oak, Graybar, Advance, Steiner, Crescent and some other supply houses and see if they can get something that will work for you.
JulieMor is offline   Reply With Quote
The Following User Says Thank You to JulieMor For This Useful Post:
BigJimmy (06-11-2012)
Old 06-11-2012, 08:52 AM   #3
Licensed electrician
Rewards Points: 1,024
Two things, the old ceiling can be broken out above the drywall so the clips will work or use the Progress P187 series housings. You can adjust the clamp height.
Old 06-11-2012, 09:02 AM   #4
Rewards Points: 720
Lightolier will work with almost ANY thickness ceiling.
http://www.lightolier.com/MKACatinstr/IS_3R.PDF
Mark
busman is offline   Reply With Quote
Remodel Light Fixtures for Plaster/Lath Ceilings BigJimmy Electrical 1 03-20-2012 08:43 AM
Installing remodel recessed lights in manufactured home. MikeVila Electrical 14 08-03-2011 08:06 AM
Recessed fixtures and suspended ceilings gdoucette Electrical 1 06-01-2010 11:16 AM
Remodel style recessed light code question bjstewa Electrical 8 05-22-2008 10:25 PM
Replacing hall light fixtures with recessed lights POMEXCAN Electrical 3 04-16-2008 11:40 PM
