Originally Posted by ssousa
Though every one calls the meter base 400A, it is not truely a 400A base but a 320A base as you are only allowed 80% of rated load by code. So while they are calling it 400A service it is not.
I just want to clear up that fact there are few 320/400 amp meter socket and they do come in few diffrent verison depending on the location and useage.
Typically in resdentail it pretty common to use the 320A push on meter socket
However some POCO required that have to be run in CT { current transfomer }
Farm are mantory 400 amp either CT or bolt on meter socket depending on the set up
Commercal automatic use full 400 amp meter socket and it will come either bolt on or CT regaurdless of system voltage and phases.
Merci,Marc
