Old 10-09-2012, 08:56 AM   #1
remodel can lights in 3/8" drywall
Are remodel style recessed light fixtures too heavy for 3/8" drywall on 16" OC joists?
This house is full of surprises.
silversport is offline   Reply With Quote
Old 10-09-2012, 09:29 AM   #2
3/8" on a ceiling
That must look like the waves in the ocean.
Unless you can get in the attic to install a new constrution can I be worred the clips on the remodel cans would not hold it tight to the ceiling or there going to break the rock as the can is pushed up into the hole.
Old 10-09-2012, 09:31 AM   #3
DIY Enthusiast
sublime2's Avatar
No. It will be fine.
sublime2 is offline   Reply With Quote
Old 10-09-2012, 09:43 AM   #4
This is in a small (400 sq ft) finished basement. Replacing the exsiting track lighting is on my to-do list and we're about to have about 1/4 of the ceiling torn out to fix old termite damage (surprise!). The termite repair is being done by a pro but with the ceiling out this seems like the right time for my recessed lighting project.
The existing ceiling looks fine (at least as far as I'm concerned). Just need to decide if I should leave the rest in place and use remodel cans or pull it all down (sure would make the wiring easier), use new const. cans and re-drywall with 1/2".
Old 10-09-2012, 10:31 AM   #5
My vote goes for replacing with light weight 1/2 or better yet 5/8 drywall.
Lights still dimming and flickerin Keisha34 Electrical 18 06-09-2012 12:14 AM
Dimming and Flickering lights in home Keisha34 Electrical 34 06-05-2012 03:22 PM
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 10:02 AM
Remodel recessed lights - Insulation contact vs non-insulation contact swaff Electrical 1 11-26-2010 04:28 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
