Remodel Box For Wall Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 01-02-2010, 03:58 AM   #1
Rewards Points: 278
remodel box for wall fixture
I am installing a wall scones, it comes with a circular slotted mounting plate. The closest thing I could find is a ceiling remodel box which is round with the flip out ears.
Are are there hexigonal remodel box similar to the metal ones? or other box I could use?
BTW what is the screw to mount the plate to these plastic remodel boxes? Is it 8/32 screws?
DIYGST is offline   Reply With Quote
Old 01-02-2010, 06:55 AM   #2
Remodeling Contractor
Yes to mount the bracket to a round or octagon box the screws are 8/32. You can get plastic 3" or 4" round remodel boxes. Or use a gem box (switch box) and madison holdits . (switch box supports or "F" clips) Not technically rated for a light but used all the time. This uses a 6/32 screw. But it is not on a ceiling so support is sufficient.
Old 01-02-2010, 07:01 AM   #3
Master Electrician
JohnJ0906's Avatar
How heavy are the sconces?
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 01-02-2010, 01:47 PM   #4
Rewards Points: 278
it's a light metal fixture.
Old 01-02-2010, 04:21 PM   #5
" Euro " electrician
frenchelectrican's Avatar
As long the luminaire is under 6 lbs you should be ok with remodel junction box but once you get over 6 lbs then you must find a stud to properly support the junction box. [ That for wall mounting ]
Merci,Marc
Old house, having light fixture issues atomiclilly Electrical 6 12-03-2009 09:54 AM
Installing One Light Fixture Causes Another Not To Work pythagras Electrical 2 07-02-2009 09:15 PM
A faulty bulb or a faulty fixture? don54 Electrical 5 12-25-2007 05:38 PM
double-ended halogen fixture bulbs stop working watt-ever-ny Electrical 6 11-20-2007 06:25 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
