-   -   remodel box for wall fixture (http://www.diychatroom.com/f18/remodel-box-wall-fixture-60786/)
DIYGST 01-02-2010 02:58 AM
I am installing a wall scones, it comes with a circular slotted mounting plate. The closest thing I could find is a ceiling remodel box which is round with the flip out ears.
Are are there hexigonal remodel box similar to the metal ones? or other box I could use?
BTW what is the screw to mount the plate to these plastic remodel boxes? Is it 8/32 screws?
Bob Mariani 01-02-2010 05:55 AM
Yes to mount the bracket to a round or octagon box the screws are 8/32. You can get plastic 3" or 4" round remodel boxes. Or use a gem box (switch box) and madison holdits . (switch box supports or "F" clips) Not technically rated for a light but used all the time. This uses a 6/32 screw. But it is not on a ceiling so support is sufficient.
JohnJ0906 01-02-2010 06:01 AM
How heavy are the sconces?
DIYGST 01-02-2010 12:47 PM
it's a light metal fixture.
frenchelectrican 01-02-2010 03:21 PM
As long the luminaire is under 6 lbs you should be ok with remodel junction box but once you get over 6 lbs then you must find a stud to properly support the junction box. [ That for wall mounting ]
Merci,Marc
