Remcon Low Voltage Electric - Upgrade Options? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-19-2011, 08:44 PM   #1
Rewards Points: 203
Hello - I'm looking for recommendations, suggestions, or any comments about a situation I recently encountered. The house I'm working on has a Remcon low voltage electric system that was probably installed in the mid-60's. The fixtures, receptacles, and relays are very old and out of date and I'm wondering what options I might have for upgrading the electric? Gutting the house is not the preferred option, it's about 3200 sq ft and there is an attic and basement. Relays are distributed around the house.
Any suggestions / recommendations would be appreciated.
Thank you!
Jim Ignatowski is offline   Reply With Quote
Old 12-19-2011, 09:41 PM   #2
Banned Electrician
HARRY304E's Avatar
Rewards Points: 204
Thank you!
I would recommend getting rid of the low voltage system and rewiring the house just fish in all the wiring like normal the house does not need to be gutted .
HARRY304E is offline   Reply With Quote
Old 12-19-2011, 10:26 PM   #3
Missouri Bound's Avatar
First of all....great name. Does everything work? The fixtures are still 120 volts, the controls are low voltage. So as long as everything works, you can replace the fixtures. The switches may be another issue, since I believe they are momentary contact. If cost is an issue you can replace things as they become inoperative. www.kyledesigns.com
Tankless gas vs. electric water heater- pros/cons gbwillner Plumbing 6 07-07-2010 12:38 PM
400 Amp Upgrade / Transfer Switch AndrewF Electrical 50 07-04-2009 08:33 PM
electric upgrade conduit clasact Electrical 6 05-16-2009 09:12 AM
electric upgrade clasact Electrical 13 10-23-2008 06:41 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
